Yaesu VR5000
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Yaesu VR5000
    I have had this radio in the workshop for some time now and am getting no-where with it. Customer reported complete loss of receive, when asked it was working one day and the next no receive. I was able to obtain part of a service manual which is little more than some pdfs of board layout, block diagram and circuit diagrams, none of these are searchable.
    Connecting this to a sig generator confirms the radio is completely deaf, I mean nothing, nada with a starting signal of 5uv upwards, I have checked this across the five bands this scanner covers and same result. Everything else on the radio works fine display, menu's buttons etc.
    Does anyone have a more complete service / technical manual for this radio, and any ideas where to start a (list of voltages and test points would be useful). I would post pics but there is nothing obvious to note on the boards just a pile of smd stuff.
    Thanking you all in advance
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Re: Yaesu VR5000
    What do you mean exactly by deaf? No static noise either? Go spray some rf right into the last IF filter with your sig geni. You should hear something, since it is the last conversion stage. That bypasses a lot of things.
    If you heave a totally dead receiver, no noise, nothing coming from the speaker, then I’d say there is something stuck in the headphone jack, the audio ic is bad, the mute jack is shorted, or the PLL is unlocked. The lock and unlock voltages and points are in the schematic.
    • llonen
      • Sep 2014
      • 495
      • hampshire
      Re: Yaesu VR5000
      Sorry my mistake, when I mean completely deaf there is simply no received rf signal, maybe the PLL is unlocked but there is plenty of static coming the speaker just no received modulated signal irrespective of frequency block or mode. One board is the RF board and the other board is the IF board plus the control board etc. I'm not sure where to start injecting a rf signal.
      I'm including scans of the block diagram to kick off.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        Re: Yaesu VR5000
        as long as you got static coming out, the PLL is locked. An unlocked PLL acts like a squelch set up high, mute button pressed etc.
        Maybe one of the IF amplifiers is dead? I had that happening on a TS-450SAT.
        did you check both antenna inputs?
        • llonen
          • Sep 2014
          • 495
          • hampshire
          Re: Yaesu VR5000
          Nods, I checked both antenna inputs there is no difference between them. Thanks for the pdf, looks like there are some voltages on there to check and additionally I was able to find an alignment guide for this radio. There are some basic test points there to look at, not that I am looking to align the radio but there are some checks there that will confirm some of whats working and not.
          Will keep you updated
          Kind regards
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8351
            Re: Yaesu VR5000
            Same thing happening on the main and sub VFO? Does the S meter do anything? Look at the first schematic on the left (scroll towards the bottom) there are test voltages for locked, unlocked and mute.
            • llonen
              • Sep 2014
              • 495
              • hampshire
              Re: Yaesu VR5000
              To date the same thing happens with the main and sub vfo, nothing shows on the S meter.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                Re: Yaesu VR5000
                go to the IF filter and spray some RF from a frequency generator in it. this way you can tell where roughly the problem is.
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Re: Yaesu VR5000
                  Now when you say spray some RF in, are you on about using something like an RF probe but in reverse
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8351
                    Re: Yaesu VR5000
                    I just use an open ended piece of RG-58 coax.
                    • Ruggero
                      • Aug 2024
                      • 2
                      • Italia
                      Hi everybody,
                      I have the same problem.
                      After few minutes or sometimes a little bit more,
                      suddenly the signal disppear.
                      If i touch some components of PLL circuit with the Point of a screwdriver, or if i use a fan to refresh some components the signal come back again.
                      Probably the screwdriver or the temperature change modify some capacity value or insert RF noise and the PLL start again.
                      IIonen did you find any solution?
                      Where is the IF filter on the scheme?
                      Thanks so much
                      Ruggero
                      • shelby5041
                        clock radio / radio lifespan?
                        by shelby5041
                        hi
                        ive got a modern digital clock radio approx 15yrs old
                        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                        it uses very little power just a few watts i would imagine that may have something...
                        09-14-2024, 03:30 AM
                      • UserXP
                        Vintage SONY Digital Clock Radio ICF-C12W no audio
                        by UserXP
                        Dear all,
                        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                        My question is, do you know of this brand of capacitors and how bad are...
                        07-21-2025, 08:35 AM
                      • praveenramavath
                        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                        by praveenramavath
                        Hello All,
                        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                        https://www.hifivision.com/threads/m...-screen.98243/
                        Troubleshooting Summary: Majority Internet Radio - Flash Chip
                        04-26-2025, 09:08 AM
                        HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                        09-12-2024, 02:00 PM
                      • Omron
                        Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                        by Omron
                        Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                        My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                        - Tried to unplug radio and plug it back in into power,
                        - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                        - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                        05-23-2024, 01:27 PM
