Horizontal streaks and distorted colors on VGA output of graphics card
  • russianbot
    • Jan 2019
    • 11
    I have an old Geforce2 GTS that shows horizontal streaks in its VGA output, and bad colors. It basically shows gray where there should be white, and dark gray ghosting stripes across the screen from text in open windows. Also the color saturation seem wildly inconsistent. I attached a photo of how it looks.
    Any ideas of what can be causing this? Damaged GPU? Or maybe some discrete components on the VGA output path that I can replace? I'm trying to figure out if it's worth attempting to fix this.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Horizontal streaks and distorted colors on VGA output of graphics card
    Did you try cleaning the VGA connectors and using another VGA cable? And not the cheapest ones on eBay, they'll exactly cause this problem.
    And obviously another display too.
    Inspect the board for bad solder joints around VGA connector or any kind of damage. Post high resolution pictures of both sides of the board.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      That looks like cruddy connectors or a cheap/bad cable to me
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • truclacicr
        • Apr 2019
        • 352
        • australia
        Try some test patterns, eg all white screen, all black, all red, green or blue. If there is a problem with a specific RGB signal path, then it should show up in these tests.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Looks like an monitor issue. Have a spare monitor to test with?
          sigpic
          (Insert witty quote here)
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            by sam_sam_sam
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
            Corsair CX750M [Model 75-002019] - burned output toroid inductor
            by momaka
            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
            09-19-2021, 08:44 PM
          • CoppellTVRepair
            Troubleshooting PFC with SPC1012T not raising output
            by CoppellTVRepair
            It has been a long while since I posted here to ask anything....hope you can help.
            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
            03-09-2025, 10:38 PM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
