Fuhjyyu 3300uF 35V TNR Replacement
  • golfather
    • Apr 2020
    • 3
    • uk
    Hi all
    Currently have a slight hum coming from my PC speakers when power is connected. Not audible when music is high volume but only on low volumes you can hear it in the background. Have a ferrite core on power lead but no difference.
    System is a TEAC Powermax 1300 - same as Hercules XPS2.100 system
    Checked the caps visually but none are bulging
    Have been advised to change the main rectifier cap which is currently a Fuhjyyu 3300uF 35V 18x32mm (not sure what pitch, probably 7.5mm)
    Is there a decent replacement anyone can recommend please? Or anything else I should be checking?
    Rest of the board seems ok
    Cheers!
  • R_J
    • Jun 2012
    • 9578
    Re: Fuhjyyu 3300uF 35V TNR Replacement
    I would check that cooked resistor (R48?) in fornt of that to220. I would also check the zener diode next to it, If that to220 transistor is a reguator or just a normal transistor acting as a voltage regulator, one of the small caps in that location might be the cause of the hum, I doubt the large cap is the issue, but if you have a 1000µf/35v just solder it acrcoss the 3300µf, if that eliminates the hum then I would replace the 3300.
    What is the number on that to220 transistor?
    The 3300 is not that special, any 3300/35v or 50v, 105 degree cap would work.
      • 31131
      thats a nice looking oldschool linear amp there!
      shame about the cap brand!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        +1
        This is probably the easiest way to determine if the big cap is the issue or not.
        +1 again
        More than likely you will find some of the small caps in there are high in ESR.
        In general, if you care about keeping this amp, I would suggest to do a full recap and not just change the big cap. Also check the cooked resistor, as R_J suggested. If it's in spec but still runs hot even after recapping the amp, consider replacing it with a bigger (higher power) resistor (of the same type and resistance.)
          I would replace that resistor with MOX type and leave the legs long so the body will be 1/4 inch. or more above the board.
          Agree on recapping for the unit this old.
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • EFritz20
            Xbox classic/original 10v 3300uf Polymer replacement?
            by EFritz20
            For polymodding an original Xbox i'm looking for polymer replacements of the following capacitor:
            2x 10v 3300uf Nichicon PW
            One is on the left side of the board, the other one on the right as you can see the picture i linked below (the two big brown caps).
            Could i just use 2200uf polymers to replace them or do i really need the capacitance?
            I have searched the forum already but could not find an answer for it.
            Thanks....
            03-25-2022, 04:47 AM
          • reformatt
            Macbook Air M2 A2681 Kernel panics after screen replacement
            by reformatt
            Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
            It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
            07-31-2025, 08:37 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • Kleist
            OCZ Powerstream PSU (Fuhjyyu 3300uF 10V)
            by Kleist
            I have an old OCZ Powerstream 520W PSU I would like to keep using. It works currently, but I opened it up and found some bulging caps which have me worried, I would like to replace these. There are:
            4x Fuhjyyu 3300uF 10V
            What could I replace these with? Where could I buy replacements that ship to Germany?
            Thanks!...
            11-08-2020, 02:11 PM
