Vintage Pace desolder station PPS-100 pump motor bad
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i jsut got this pace PPS-100 desolder solder station vintage for free
    the motor does not turn when powered on..it just makes some rumbling sounds thats it
    no replacements avail for reasonable price..
    is this fixable or maybe an alternate motor
    here is a pic of stock photo i found online
  • shelby5041
    • Feb 2009
    • 1505
    Re: Vintage Pace desolder station PPS-100 pump motor bad
    nevermind i fixed the issue..motors works good now
    • redwire
      • Dec 2010
      • 3912
      tell us what you found and fixed lol. The motor capacitor might be low value.
      • shelby5041
        • Feb 2009
        • 1505
        Sure..there is a plate on back of motor where vsc is...with a thin shim.metal gasket ..i took plate off pkate and motor turned fine by hand so i put plate and shim metal gasket back on ...it then worked...apparently it was bound up against the plate...from years of idled...my neighbor gave me it...its very interesting...even has a rotary tool..)
        • llonen
          • Sep 2014
          • 495
          • hampshire
          I was looking for a replacement pump for the MBT 250, well more specifically the diaphragm overhaul kit, then unable to source that my thoughts turned to a replacement pump / motor assy and found prices for second hand units were not meeting with my approval. In the end was able to source a complete replacement controller at a very cheap price that did meet with my approval lol.
            ZD-915 vacuum pump motor mount service alert
            by sam_sam_sam
            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
            09-19-2021, 02:15 AM
          • juergenb
            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
            by juergenb
            i am asking for some Help.
            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
            So i got a few of these from Banggood.
            I swapped the motor and now i have a new fault condition.
            In a working Frother you would press the start button, it will light red and work for a few minutes.
            If you press longer it will light blue and just mixup the milk.
            With the new Motor it just starts...
            03-23-2021, 11:24 AM
          • sbt123
            charnwood w821 mini wood lathe motor problem
            by sbt123
            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
            10-27-2024, 03:43 AM
          • mikey5791
            Help identify this motor
            by mikey5791
            Hi all forum members,
            Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
            Correct me if i am wrong on the initial test.
            Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
            11-24-2023, 07:54 PM
            1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
            by sam_sam_sam
            I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
            This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
            12-29-2024, 07:18 AM
