DELL U2311Hb (E162032 Vol 3) Goes Black After 2 Seconds
  • Drith
    • Apr 2020
    • 6
    Hello! I have a DELL U2311Hb monitor (mfg. May 2010) that will show a regular picture for 2 seconds and then go dark. The green power light stays lit but the screen is black and the menu buttons do not function. The power supply board says it is E162032 Vol 3. I looked at all the capacitors and they seem visibly fine.
    I tried testing each of the radial capacitors with a regular multimeter's resistance meter set to around 20k. I watched signal build on them (some of them I had to turn up the measurement to 2000 because they'd slow down and get stuck). All of them eventually went to infinity except one: C765. It settled in the middle and even when I set my multimeter to diode it would not go to infinity.
    My plan was to de-solder all the brown/black/green caps and buy new ones from Digi-Key to put on. Is there a better place to buy them from? One I found to replace C765 (220uf 25V) was this one. Does it look like a good choice?
    Should I buy an ESR Meter, and if so which one? I saw this LCR-T4 Mega328 on eBay for $9. Is it any good for testing bad capacitors?
    Any assistance would be most appreciated!
  • Drith
    • Apr 2020
    • 6
    Re: DELL U2311Hb (E162032 Vol 3) Goes Black After 2 Seconds
    I tested all the resistors, the fuse, and the transistor and they seem good.
    • Drith
      • Apr 2020
      • 6
      I removed C765 and tested it with the multimeter. Now that it's removed from the board, it seems to test properly and when I set to measure 20k Ohm the resistance gradually rises and then goes to infinity just as the other caps do.
      The board has a dozen caps. Should I buy replacements for all of them and try that, or is the problem likely somewhere else given they seem to test fine and they don't look visibly damaged?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8331
        Could be anything, from bad solder joints, bad capacitors, transformer going bad, bad connection somewhere...
        You can’t check the health of a capacitor, by charging it up with your DMM in ohms mode and watch it climb. Only because they “look” good, doesn’t mean that they are good either. If you want to check caps you have to invest into an LCR or ESR meter.
        • R_J
          • Jun 2012
          • 9594
          Check the voltages on the plug to the main board and see if they remain when the moniitor blanks out. I would suspect one of the ccfl's has an issue, either bad/broken ccfl or broken ccfl lead.
          You may have a bad ccfl in the panel, there are 4 ccfl's, 1,2,3,4 so unplug 2,3,4 and see if you get a flash of backlight from ccfl #1 (this may be fairly dim) If you do see a flash of the backlight, unplug 1,3,4 and try again with #2, trying each ccfl by itself should confirm they are working or not. In some cases the wire on the ccfl breaks and that is all that is wrong.
          • MeinFreund
            • Oct 2013
            • 12
            I know its a different DELL model, but it sounds similar to the problem described here:
            https://www.badcaps.net/forum/showth...699#post663699
            • Drith
              • Apr 2020
              • 6
              Thank you all sincerely for the replies! To aid searching and such, the power board says it is 4H.14W02.AF0.
              You make a good point that without narrowing it down, and without an obvious issue from visual inspection, the issue could be anywhere and so I should focus on narrowing down the issue. Is there a budget LCR/ESR meter you might be able to recommend? Is the LCR-T4 Mega328 sufficient?
              I did the flashlight test and can see the silhouetted picture! However, now the monitor does not flicker on at all. The blue power led switch lights, the set stays black, but I can see a silhouette with the flashlight. Does that mean the issue is likely the CCFLs or the power supply going to the CCFLs, and so not the main board?
              I tried disconnecting the four cables running to the panel leaving one plugged in at a time but it did not seem to have any effect. I could still see the silhouetted picture, but no backlight. I then tried having them all plugged in except one and it had no effect either.
              I tested the voltages to the main board as follows. When the monitor is turned off, the 3rd pin that read 2.5 drops down to 0.02 and the fourth that read 0.65 drops to 0.12. The rest of the voltages stay the same whether the monitor is on or off.
              I have checked over the threads and their monitor seems to be significantly different than mine. I don't see the transformer array or backlight tubes on mine, at least not in the same place. I attached full pictures of the monitor's guts.
              • Drith
                • Apr 2020
                • 6
                What other tests or process can I go through to determine what is wrong? If it's the CCFLs that are burnt out, it looks like I could buy an LED replacement for pretty cheap but I'm not sure how to determine if that's the issue. Or if the power supply board is the issue, how can I check that?
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Omar Villalba
                  Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA) schematic
                  by Omar Villalba
                  Good morning, colleagues.
                  I'm looking for the schematic or boardview for a Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA).
                  I would really appreciate it if someone could share it.
                  My main issue is that the backlight is not working. I found fuse F5503 to be blown; I replaced it, but it blows again (goes into protection).
                  It's worth noting that there's no short on the fuse line, so any guidance or similar experience would be greatly appreciated.
                  08-12-2025, 09:21 AM
                • DrFalken
                  Dell Inspiron 5593 shutdown after 5 seconds
                  by DrFalken
                  Hello everyone!
                  Motherboard model: FDI55 LA-J081P
                  Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
                  I found and replaced a shorted MOSFET (PQZ3).
                  Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
                  BIOS has already been updated (both 64MB and 128MB IC)
                  +3VALW and +5VALW are still present.
                  +VCCIN = 1.8V stable (measured on PLZ1 at power up)
                  Abnormal readings:
                  PLZ1 to GND = 0 Ohm
                  PLZ2 to GND = 0 Ohm
                  04-09-2025, 10:45 AM
                • Akhlz001
                  Dell Pro 13 Plus PB13250 Bios Unlock
                  by Akhlz001
                  Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                  09-20-2025, 07:15 PM
                • Kambi13
                  Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                  by Kambi13
                  Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                  Not heat related, everything is ok regarding to that.
                  All voltages are present.
                  Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                  Motherboard is Cedar 13269-1 F3XMC Rev A00...
                  07-12-2024, 06:10 AM
