ATX PSU recap and upgrade
  • PowerHP73
    • May 2020
    • 3
    • Italia
    Hello guys. I would like to replace the secondary capacitors of an ATX PSU. It currently mounts cap-coil-cap filters for 3.3/5 and 12v. Teapo 1000uF. I'd like to fit in some better-performing Japanese capacitors. Do you advise me to go up with microfarads (I was thinking about 3300uf) or is that a bad idea? A friend explained this to me: "Be careful because the coils on the secondary should be sized to use the expected capacity condestors, it is not said that by increasing the ripple it is reduced, it could create noise at frequencies that with the larger capacitors are no longer filtered correctly." Thank you in advance
    • 31140
    Re: ATX PSU recap and upgrade
    keep the capacitance and esr similar,
    your friend is right and the caps and coils are matched to create filters.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      generally, capacitors are made with a ±20% tolerance from the factory. so if the original is 1000uF, u could still replace it with a 1200uF without going out of tolerance or out of spec of the design of the original and still stay within spec.
      the other practicality issues with bumping up the capacitance too much is that higher capacitance caps will undoubtedly have a bigger can size. they may be wider (fatter) or taller. if that is the case, they may no longer fit on the board if there isnt enough room to accomodate the larger size caps.
      the next issue is that larger sized caps will also have lower esr from their bigger can size and too low esr will also cause unwanted side effects to the function of the circuit. so these are the practicality issues that arise from upsizing the capacitance of caps excessively and are not recommended for practicality reasons.
      • PowerHP73
        • May 2020
        • 3
        • Italia
        thank you for the answers. So I guess I'm going to use 1200uF. To improve the outbound filter add a third capacitor ? So cap-coil-cap-cap? Is it madness?
          • 31140
          it will look like one huge output cap - pointless.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            yea maybe i should have been more clear with my reply. not only the individual capacitance has to be within spec but the total overall bulk capacitance also has to be matched. if the filter has two 1000uF caps, this means the total bulk capacitance is 2000uF. if u add a third 1000uF cap to the filter, the total bulk capacitance would then be 3000uF which is out of spec of the original bulk capacitance of 2000uF.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Assuming it's a properly designed and built PSU, this is probably true.
              However, without seeing the PSU, I can't say if the O/P should use the same/similar capacity caps or not.
              Remember, manufacturers will sometimes cut corners to cut costs (or rather, make larger profits) and use smaller caps than what the PSU was designed for originally. Generally, that's the case with cheap "gutless wonder" PSUs. For those, I recommend not to follow what's in the PSU and instead use *at least* 2x 2200 uF caps on each major rail, with the 12V rail probably sufficing to have just 2x 1000-1500 uF caps if the PSU is rated for 300 Watts or less.
              Of course, if the PSU is built properly, then you should try to stick to same or similar capacitance. In general, though, going up to 2x the capacitance will not hurt anything. There are very few PSUs that I've seen "freak out" with larger capacitance, and they were both from the same maker - Sirtec. So except for those, larger capacitance actually helps bring the filtering frequency lower and makes the circuit even less likely to oscillate. In most cases, increasing the capacitance within reason will have positive effects.
              I don't know about going to 3300 uF caps if the originals were 1000 uF only. But going 1500 uF or even 2200 uF will likely be OK (if not better.)
              ESR is where you want to stay more similar to what the original circuit had. But even there, I find there are often exceptions that can be made. For example, PSUs with a linear 3.3V -generated rail won't really care that much if you use normal low-ESR caps mean for PSUs or GP 105C caps not necessarily suitable for PSUs. In either case, the ripple on a linear circuit is more or less strictly based on capacitance and not ESR. Likewise, a PSU with a mag-amp -generated 3.3V rail will typically be able to take ultra-low ESR caps (i.e. much lower ESR than the originals) without problems. The 5VSB rail also often falls in that category (though using ultra-low ESR caps on the 5VSB can sometimes make it produce audible "whining"... which may be annoying to the user.)
              All in all, PSU output caps are not an "exact science" of what you can use. You can also lower the capacitance too in many cases, if needed. But then the PSU wouldn't be able to output the same amount of power on that rail without noise becoming too high. In other words, you can increase or decrease output capacitance based on how much load you expect the PSU to see or how much output ripple you're willing to accept as "maximum". That's how manufacturers sometimes build PSUs on the same PCB, but one with more/bigger output capacitors than the other, based on how they want to rate the PSU in terms of power output, noise filtering, and cost.
                by momaka
                03-15-2023, 10:17 PM
              • chth96
                What capacitor should I purchase for Power Supply of obsolete game consoles?
                by chth96
                hello.
                I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
                It hardly ever freezed after I finished to recap all of caps in the power supply.
                But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
                To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
                It seems that quality...
                10-01-2024, 08:14 AM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
                Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                by momaka
                This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                Macron Power Technology Co. LTD.
                Let’s look at the PSU itself.
                The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                06-02-2021, 10:05 PM
              • Junkrepair
                Calculating ESR from tan delta -- tan delta's dependence on capacitance
                by Junkrepair
                I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                I found this nice little description of the conversion:
                Calculating capacitor ESR from Tan(delta)
                https://forum.digikey.com/t/calculat...-from-tan/2633
                It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                06-12-2023, 02:45 PM
