Anyone recognize this power supply?
  • Cartel
    • Feb 2006
    • 112
    Its 13.8v and unknown amps, 100?
    There is no name and it has 5 identical modules in it.
    Dont know where else to ask.
    thanks
    • Jul 2011
    • 6070
    Re: Anyone recognize this power supply?
    It could be a forklift battery charger would be a good guess
    But very old model is my guess
    I would test each module by it self just make sure pay attention to how it is hook each other
    I would expect that to start the charging cycle you probably have at least a minimum of 8 to 10 for it to start charging would be my guess
      • 31293
      not a forklift, the cells are in series - 48v or higher.
      it could be an early solid-state charger for garages though.
      • R_J
        • Jun 2012
        • 9624
        It might be from a audio display system used in stores.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Naw... doesn't have big enough filter caps. Looks like it used to run a lot and someone knew how to fix it (a lot). The screw holes are worn, extra grounding lug...
          My guess, a commercial PSU, ran something in some sort of an transmitter site. Second thought: An shore charger for the battery bank on a boat?
            Any printing on the circuit boards at all?
            • PeteS in CA
              • Aug 2005
              • 3583
              • USA, Unsure of Planet
              I think I saw a 1989 date code on that silver-colored 85C 1000uF made by El Cap.
              PeteS in CA
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                strange coil on the output . and what looks like a motor cap .
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
