Remove rear panel Sony Bravia KD-65X7500F
  • viewerau
    • May 2020
    • 305
    I am from Australia, and thank the mods for allowing me access to your forum...thanks.
    I have a 2018 Sony TV, and am in trouble trying to remove the back panel to replace a broken power supply board, that I have already purchased.
    I have removed all 18 screws from the rear, as well as another 4 that are used to secure the legs.
    I had the panel face down on a soft surface, ready to change things over, but cannot seem to work out how to get the back off, and I see nothing else to undo, to do so.
    I believe that in the US and elsewhere, my model is probably just known as the KD 65x750.
    It is this one, from the sony australia link
    https://www.sony.com.au/electronics/...specifications
    Here is a photo of the rear of mine.
    https://imgur.com/a/yHlRpVW
    If anyone may be of assistance to me, I would be most grateful for their help.
    Thank you...
    Signature:Seemingly hopeless tv fixer
  • nomoresonys
    • 12212
    • U.S.
    Re: Remove rear panel Sony Bravia KD-65X7500F
    Nick's removing the 65X930, thinking it should be very similar to your model: https://www.youtube.com/watch?v=rVftkD0GFoU
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Looks like the wall mount adapters were the problem. I'm glad I watched this video.
      • viewerau
        • May 2020
        • 305
        Hi.... many thanks for your reply.
        The rear of mine is completely different...please see previous link to photo.
        I am still stuck.there must be some internal clips or pressure points I have to find to release it.
        Tv has been off for 3 months, so pretty sure any power in the capacitors should have dissipated?
        Thanks....will keep trying.
        • budwich
          • Jul 2015
          • 3097
          only suggestion based on my limited sony (and others) is to work at the low area where you have already removed "visible" fasteners. There are "plastic retainer fingers" on the inside of the panel even though the fasteners are used.... somewhat for alignment purposes but also for assembly construction. Usually in the corners and mid way areas... they are almost like car interior panel retainers (male / female) but of course, less stature / size.... as opposed to small "side plastic tabs" that you see in remotes, tablet devices, small electrical plastic enclosures.
          Looking at the picture of the back, I think you can see where the "male" portion of the "retaining fingers" are situated in the lower panel (small indented "dots").
          • nomoresonys
            • 12212
            • U.S.
            Ok, I didn't look at your imgur, I very seldom look at photos that are not uploaded right here.
            • viewerau
              • May 2020
              • 305
              Thank you very much for your replies...they are appreciated.
              On the rear, there are also a number of spots that are raised, or similar to screw holes, but have a polished look....maybe these are where the fasteners are?
              This time I will upload the image...I didn't before, as sometimes some forums prefer links over photo's cluttering their forums...cheers.
              • brucetv
                • May 2015
                • 281
                • united states
                Here is a picture of your back cover. There are flathead screw tops under these red circles that holds the top down. You have to slide the whole back cover upwards in the direction of the red circles. Once the cover clears those flathead screws it should come off if it's that type. Sony keeps you guessing.
                • viewerau
                  • May 2020
                  • 305
                  Thank you brucetv...I will try with your suggestion.
                  Much appreciated...
                  • viewerau
                    • May 2020
                    • 305
                    Hi again...no success I'm afraid.
                    I have prodded and pushed on all those areas and simply cannot get anything to give.
                    I can get my fingers under the sides where the RF and HDMI slots are, but the side sections seem gripped solid to the areas above the level of where the speakers are. Shining a mini torch through the side panels when prized up about 1cm shows me nothing either.
                    I guess I have to take it to a repairer just to get it off..that sort of defeats my cost savings plan....
                    Grrr
                    • brucetv
                      • May 2015
                      • 281
                      • united states
                      Most of the time when I can't get a damn back cover off I find I'm missing a screw. Take a bright flashlight and shine it in every hole especially those deep square holes where they sometimes have rubber grommets covering them. Also look on the bottom of the tv for small screws holding the bottom down. Sony tends to over complicate things.
                      • viewerau
                        • May 2020
                        • 305
                        Thanks again,
                        Here is another collage of what it looks like
                        I have taken a bright tiny led torch and there is no additional screw holes to be found.
                        Every nook and cranny has been tested, even another set of eyes could find nothing additional.
                        This is driving me crazy......
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Do the red arrows point to torx screws???
                          • viewerau
                            • May 2020
                            • 305
                            No screws up there at all.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              What are the round marks the red arrows point to?
                              • viewerau
                                • May 2020
                                • 305
                                Where another poster in the thread said there were some screw heads under that cover area. I cannot see or feel anything there to pop them off of, that may be under that area
                                • nomoresonys
                                  • 12212
                                  • U.S.
                                  See if it works like that one: https://www.youtube.com/watch?v=2WtD...ature=youtu.be
                                  • nomoresonys
                                    • 12212
                                    • U.S.
                                    If not that then I think it's as a few have already mentioned: Once you have all the screws out from the back you want to wack the panel from the bottom towards the top of the tv. Essentially there are fixed screws that the back panel is resting on like a picture rests on a screw in the wall. So you want to push it up in the same plane as the tv panel. If you force the back away from the tv you will break those snaps. There are around 4 or 5 screws across the inside the cover so it can take a lot of controlled force to knock the panel off the screws.
                                    • viewerau
                                      • May 2020
                                      • 305
                                      See if it see if it works like that one..... different I'm afraid as there are no latches to be seen.
                                      When people say to whack it from the bottom, I can't get my head around it, as the panel cover cannot still move, as the outputs for such things as optical, and where the RF input is, that they extend through the cover, not enabling it to slide up or down. In the pictures,you can see there is both a solid type section above and below the central panel area, and they seem rock solid, stopping any sliding motion.
                                      I can get both edges of the central main cover to lift slightly, but not enough to see any clips there that need uncoupling.
                                      Thanks everyone for the help so far ... I did ring a local Sony tv repair agent, but he was reluctant to reveal the actual procedure, but I can understand him in not saying, as it is his livelihood after all
                                      Hmmm
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Does the top half of the rear panel slide downwards?
                                        • guidodroid
                                          Bad Panel in Sony Bravia X850G
                                          by guidodroid
                                          Hello all,
                                          I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                          It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                          Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                          The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                          03-19-2022, 12:08 PM
                                        • m4a2t0t
                                          Sony Bravia 75X850C panel
                                          by m4a2t0t
                                          After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                                          Does Sony epoxy all their panels or just the expensive ones?
                                          12-07-2023, 05:43 PM
                                        • swrb898
                                          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                          by swrb898
                                          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                          Problem:
                                          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                          My troubleshooting got me this far:
                                          With the left-hand TCON to bottom-board ribbon cable...
                                          12-28-2021, 08:12 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
