Laminator blows fuses and trips the mains - but not when on my ispolation transformer
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    So here is a 'weird device' it is an IKON IP-450 A2 Paper laminator
    The customer says it was warming up then suddenly tripped out the 220V mains
    He replaced the 5A fuse which had blown but it did the same thing straight away as soon as powered on, it trips out the power in his apartment. He tried another power lead and tried it at a friends address but the same occurs
    So he brought it to me, having fitted a new fuse again.
    I plugged it in and it worked fine - it was drawing about 3Amps and warmed up to maximum working temperature no problem in about 5 mins.
    Having scratched my head as to why, it occurred to me the only thing I was doing different was that I had it connected to my 220V isolation transformer.
    So I connected it to a normal power outlet, it blew the fuse instantly and tripped the mains out. The fuse is vapourised.
    I then replaced the fuse, put it back on the 220V isolation transformer and it works fine
    Thing is I can't see any shorts to explain this, either across the power or to ground. The heating element does read short circuit on my multimeter, but it obviously works OK.
    The only thing I can see is one of the plastic terminal blocks that connects the power to the heating element has melted and looks a mess, but there is no short form this terminal to ground or to the screw next to the terminal block
    So what's going on and why does it work on the isolation transformer?
    Follow me on YouTube
    Learn Electronics Repair
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Laminator blows fuses and trips the mains - but not when on my ispolation transfo
    earth leakage ..isolation transformer won't have an earth .
      • 31254
      that or the isolation transformer is current-limiting
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        +1
        3A @ 220V is 660VA -- probably a sizable load for an isolation transformer. If it was fused at 5A then it is likely that it draws close to that (at least at some point in its operation).
        If there was a partial short (to earth or elsewhere), it would have to be significant (enough to make a difference between a ~3A operating current and a >>5A fuse trip current) for the fuse to "blow instantly" -- not likely something "moving" from thermal expansion, over time.
        Put a light bulb in series with the load and measure current draw off the mains (w/o transformer).
          • 31254
          a lot of these things use a halogen lamp inside a metal roller, the cold inrush is huge!
          • R_J
            • Jun 2012
            • 9607
            I would disconnect the heat element and see if the short is still there, it could be that the heat element is shorting to ground, maybe only when it heats up.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              OK I can try with the heater disconnected
              Just to clarify a few points raised...
              My Isolation transformer is 220V:220V and rated at 2000VA continuous. It's good up to about 8 Amps (I know that from previous usage) It has a built in thermal trip and it did not trip out.
              That connects to my Variac which is also rated 2000VA. On the Variac I had it set to 100% output voltage and the Laminator was connected to that. I do have a light bulb I can switch in series with the load but when i first turned on the bulb did not light so I bypassed it.
              The Variac has linear voltage and current meters - that is how I know it was drawing 3A at 220V.
              I had it on for a good 5-10mins until the led went green to signify the laminator is up to the set temperature. The owner who was there says this is normal behaviour. So I honestly don't think the isolation transformer is an anyway acting to decrease the load
              To vapourise the fuse a lot of current must have flowed instantaneously when I connected it directly to the mains. My thoughts were the same as some here - a short to ground. But I can't see it on my DMM.
              • redwire
                • Dec 2010
                • 3912
                Look in the pic, the terminal block has melted and is shorting to the mounting screw.
                • R_J
                  • Jun 2012
                  • 9607
                  With the laminator on the isolation transformer, when the short occurs you will be able to measure a/c voltage between a/c line and what would normaly be chassis ground. Without the short there should be next to 0 volts between a/c line and ground. And as mentioned above, it could be the shorting right at the white terminal strip
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    Yes I thought exactly that as well. And as I posted on the OP I checked the terminal to the screw (or chassis) reads open circuit
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      Yes, This. Very good suggestion, I will try that tomorrow. Thanks mate. I did check that white terminal already though, and it reads fine. Tomorrow I will remove it and fit something new just to eliminate it anyway.
                      • redwire
                        • Dec 2010
                        • 3912
                        Uh, give it a wiggle
                          • 31254
                          lol
                          and a good place for a ceramic terminal block and bootlace-ferules!
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            OK it's fixed. It was that screw where it went through by the melted terminal block. It read open circuit from the terminal to the screw on my multimeter, even if I tried waggling the connector which actually would not move. But once I removed the screw and cut the melted part of the connector away I could see there was some bare metal inside and it had been arcing in there.
                            I didn't have any ceramic connector blocks so I soldered the wires and used heatshrink and then that white heatproof sleeving.
                            It works fine now
                            Rich
                              BTW, Did you tighten all the screws on that terminal block, the one that melted was due to bad contact resistance so it got hot and melted the terminal black.
                                Surface Mount Fuses Fundamentals Datasheet
                                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                10-07-2024, 06:07 AM
                              • acedogblast
                                Power supply for main amp blows fuses after replacing filter caps.
                                by acedogblast
                                Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                02-27-2023, 05:11 PM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
                              • valvashon
                                Samsung UN65KU6290F PS board blows fuses
                                by valvashon
                                Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                                Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                                11-27-2023, 01:09 PM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
