Lg 32lb5700 no power on led
  • axon18
    • May 2020
    • 7
    • Portugal
    Good Morning,
    I have a TV that suddenly stopped showing pictures. After searching in the internet, i find that could be the LED tapes. I opened the TV and it really had a burnt and scorched tape led ... i replaces them all.
    When I connected everything is the same.
    Can you help me?
    I attach the photos and measurements on and off.
    Sorry my bad english.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lg 32lb5700 no power on led
    You are missing a signal from the mainboard to turn the leds on. DRV_On should be approximately 3.5V
    Disconnect the mainboard from the power supply and connect a 1K resistor from 3.5V to PWR_On and a second 1K resistor from 3.5V to DRV_ON
    • salarsat
      • May 2020
      • 1
      • iran
      Hello
      your board need to be reball CPU !!!!
      do not tuch any thing !!!
      • nomoresonys
        • 12323
        • U.S.
        Originally posted by salarsat
        Hello
        That's just a HUGE assumption.
        • axon18
          • May 2020
          • 7
          • Portugal
          Hello, i make what you said and the led poweer on, then i disconnectt the led and check 142vdc in led connector.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            So the backlight works when you tested using the resistors, yes?
            • axon18
              • May 2020
              • 7
              • Portugal
              Yes
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                It looks like you have a mainboard problem not providing the signal and your leds are OK.
                Can you follow the DRV_ON pin on the mainboard and see if it connects to a transistor/mosfet.
                • yokoono
                  • Apr 2010
                  • 516
                  Or reflow to the processor.
                  • axon18
                    • May 2020
                    • 7
                    • Portugal
                    After search i find that c701 is missing, there is olny the place with solder.
                    I attatch picure with the pin DRV_ON and the component that is missing.
                    And i don't know what is...i search the board but i can't find the manual..eax65610905
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Why would the smd capacitor C701 be missing? It does look as though it is. Was this TV working for you or do you have it for repair? Has the mainboard been replaced or worked on?
                      • axon18
                        • May 2020
                        • 7
                        • Portugal
                        The television was working. It was on a living room sideboard and then I posted it on the wall. after that it worked a few hours.
                        It wasn't to fix. It won't pay off. Appliances are very expensive to repair here.
                        Can you tell me what componet i have tu buy tu put there.. to see if works.
                        Regards
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Unfortunately, I do not know what the component is.
                          Perhaps someone with an identical board could tell you but there would be no guarantee that that is the only problem. There also appears to be an smd resistor alongside that is not in circuit so it may be that they were never included in this version of the mainboard.
                          • nomoresonys
                            • 12323
                            • U.S.
                            That's where a MLLC capacitor would go, see all the others, look around tho, maybe this setup did not require that cap, there are many more places on that board that don't have those caps in place, see them, just because there's a place for one does not mean it was needed in this particular setup/configuration.
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              That's definitely looks broken off, non filled pads have more rounded solder domes. I have an identical board here and have just pulled that capacitor, it's 10uf.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                There's also an smd resistor in the photo I posted that I could not see on his original photo. Is it on your board and can you see its value.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  It's tiny and black which is why it doesn't look like it's there. It's in circuit with the two black devices either side of it, it sits lower than them so it's very unlikely it could be knocked off, unlike that cap.
                                  • nomoresonys
                                    • 12323
                                    • U.S.
                                    Yep, looks like it fell off or was removed, what's the tv history? another pic. there: https://www.ebay.com/itm/LG-32LB570V...-/273575219348
                                    • axon18
                                      • May 2020
                                      • 7
                                      • Portugal
                                      Good evening,
                                      Thank you all for your help. I ended up buying a new card.
                                      • nomoresonys
                                        • 12323
                                        • U.S.
                                        Ok, let us know if it works.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
