Eprom programmer suggestion.
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    I need a tip. I have to buy a new eeprom programmer. I work a lot with Apple products (Laptop and Imac). These products use Winbond 25Q64FV and above serial flash. I need a product that has a very updated and updatable database and that does not cost excessively.
    we are currently using a Baghero but it is no longer upgradeable. In addition, the new model is very expensive.
    Any suggestions?
    Thanks for your help
    • 31259
    Re: Eprom programmer suggestion.
    look at the TL866II+
    it can program down to 1.8v and is often updated.
    http://www.xgecu.com/EN/TL866_main.html
    https://www.aliexpress.com/item/32992209964.html
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8342
      I'll second what stj said above.
        • 31259
        and you DO want to spend the extra for the black edition, the aries chipsocket is 1000x better than the green ones!
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I downloaded TL866II+ manual, not exactly amateur-friendly for following:
          Can it reflash a SOIC8 SPI chip in situ?
          What accessories need to be purchased to handle this? (appreciate links)
          Am I correct that a Pomona clip is best for SOIC8 end? (also appreciate compatible link/s)
          • Repdata
            • May 2020
            • 67
            • Deutschland
            Hi
            I'm using the new XGexu T56 23141 Chips Supportedhttp://www.xgecu.com/en/
              • 31259
              the tl866 comes with the isp cable, but not all chips can be flashed on the board - it depends on the actual board.
              i wouldnt know about clips, i have a generic $2 chinese one - it does it's job.
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                im using EZP2010 programmer it works fine even with 1.8v eeprom but of course to be safe you need an adapter for that. and also buy the sop8 socket 150mil and 200mil .
                Never stop LEARNING because life never stops TEACHING!
                • dorindon
                  • Aug 2020
                  • 3
                  • Europe
                  The EZP2010 programmer is pretty good deal
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    I'll third what stj says!
                    The TL866 is very easy to use - it must be because it is the first eprom programmer I have owned, and I had no problem using it. There was a video on eevblog and that was all I needed.
                    I got one from aliexpress and it works fine
                    Follow me on YouTube
                    Learn Electronics Repair
                      • 31259
                      download and try the software - if it cant see a programmer it runs in demo mode
                      http://forums.xgecu.com/viewthread.php?tid=20&page=1
