LG 49UF6400 tint on half of screen + no OSD?
  • Ifixstuff9
    • Jul 2017
    • 120
    I have a LG 49UF6400 with two issues. The first is a colored tint on the left side of the screen. The color of the tint depends, but I've seen red, green, and purple so far. I can see a normal image behind the tint as shown in the photos. The tinted side flashes rapidly between "normal" and "tinted"
    I suspected either the panel or the TCON, so I tested the TV with one of the panel cables disconnected. With the left side unplugged, the left half of the screen is white and the right is black. With the right unplugged, the left has vertical bars and the right is white. I have attached photos.
    At this point I felt sure that at was either the panel or the TCON, but there is another issue as well... I can't get the TV to generate ANY on screen display. At no point when testing the TV did it display and content of its own, such as a "no signal" message, the LG logo on startup, the settings menu, the built in apps, etc. If I power it on with no video source I only get a black screen (with the tint mentioned earlier) until I hook it up to a video source, at which point it will display only that.
    At first I thought the TV was completely unresponsive but that isn't true. This TV has a frame dimming feature, and I've noticed that if I display a black image on my video source (which causes the backlit to dim) and then press, for example, the menu button, the backlit will ramp up while the invisible menu is open and dim again when I press exit. So it seems like the TV is generating a menu and adjusting the backlit accordingly, but it won't display it.
    I've never seen or heard of the second issue before. What do you guys think? If the TV can't display an OSD in addition to the tint, does that imply that both the mainboard and TCON/panel failed, or could all these issues be caused by the mainboard itself?
  • nomoresonys
    • 12305
    • U.S.
    Re: LG 49UF6400 tint on half of screen + no OSD?
    Tcon there for 25 bucks, might be the problem, there's also one for 18 or 19 but it's on a slow boat from china: https://www.ebay.com/itm/LG-6871L-42...AAAOSwDQxezqJ5
    • Ifixstuff9
      • Jul 2017
      • 120
      I added the TCON to my watch list, but I don't want to spend money on this TV just yet because I still haven't figured out why it won't display an OSD. Surely the TCON has nothing to do with it, right?
      I also noticed that the two chips I circled in the picture got VERY hot even though the TV had been running for less than 30 minutes. Seems strange that they would generate that much heat in so little time, especially considering that the TV wasn't running built in apps or doing anything "demanding"
      • diif
        • Feb 2014
        • 6978
        • England
        That's a BGA issue on the mainboard not a tcon issue.
        • Ifixstuff9
          • Jul 2017
          • 120
          Hmm, any idea where I can find a reasonably priced mainboard for this TV? Only one I could find on eBay was $175, and it seems to be out of stock everywhere else.
          • neilc6
            • Nov 2015
            • 1550
            I have used this seller before for main board repair with no issues. Not sure if it will correct your problems so you can contact him first.
            https://ebay.us/h6udhv
            • Ifixstuff9
              • Jul 2017
              • 120
              Thanks for the suggestion, I contacted him and he thinks he can fix it. I'll post an update when I get the board back
              • Ifixstuff9
                • Jul 2017
                • 120
                Final update, I installed the repaired main board and TV works fine now
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • Yehuda170
                  ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                  by Yehuda170
                  original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                  replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                  now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                  with original broken screen i can see in device manager touch screen in human interfaces
                  but with the new screen it's not showing in device manager
                  is it lenovo blocking it? is it driver missing?
                  I²C is a headache
                  07-14-2023, 01:29 AM
