Can I swap LCD screen LTN173KT02-801 with a LTN173HT02 ?
  • G33RT
    • Oct 2016
    • 69
    • Belgium
    Do some of you know if it's possible to swap a laptop LCD with another model number ?
    For example: Samsung LTN173KT02-801 with Samsung a LTN173HT02
    Regards, Geert
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Re: Can I swap LCD screen LTN173KT02-801 with a LTN173HT02 ?
    yes
    • G33RT
      • Oct 2016
      • 69
      • Belgium
      Damn it did not work.
      The 40pin LVDS connector has not the same pin assignment than the orignale LCD screen.
      Regards, Geert
      • G33RT
        • Oct 2016
        • 69
        • Belgium
        I found out that the recommended LCD's are not compatible with my X770 laptop !?
        I did some reverse engineering and traced all from the JLVDS mainboard connector to the 40pin LVDS connector and this is how they are assigned:
        LVDS 40pin Mainboard JLVDS connector
        1 - NC
        2 - GND
        3 - TXCLK- 6
        4 - TXCLK+ 4
        5 - GND
        6 - Lane2+ 17
        7 - Lane2- 19
        8 - GND
        9 - Lane1- 15
        10 - Lane1+ 13
        11 - GND
        12 - Lane0- 11
        13 - Lane0+ 9
        14 - GND
        15 - LCD EN VDD 24
        16 - LCD LED PWM 20
        17 - GND
        18 - 5.1v LCD VCC
        19 - 5.1v LCD VCC
        20 - 5.1v LCD VCC
        21 - 5.1v LCD VCC
        22 - GND
        23 - GND
        24 - GND
        25 - GND
        26 - GND
        27 - 1.1v (+3v LVDSDDC) 28
        28 - 19v GND
        29 - 19v GND
        30 - 19v GND
        31 - 19v GND
        32 - 0v (BKLT_Enable) 35
        33 - 3.0v (BKLT_PWM_DIM) 26
        34 - NC
        35 - NC
        36 - 19v LCD VCC
        37 - 19v LCD VCC
        38 - 19v LCD VCC
        39 - 19v LCD VCC
        40 - NC
        How can I find out which LCD screen fits my laptop ?
        Regards, Geert
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Firstly, the old and the new screen must be pin-compatible. Then, there are some other factors that have to be considered such as screen size and location of connector. For more info, read this page:
          https://www.badcaps.net/forum/showthread.php?t=80477
          If the new screen is not pin-compatible, do not connect it to the laptop.
            • 22279
            The LTN173HT02 is a 3D screen,there are some X770 models with one.The compatibility,the LVDS cable,header, motherboard revision or bios may be different though.
            • G33RT
              • Oct 2016
              • 69
              • Belgium
              So how can I find a correct LCD screen for this laptop ?
              Regards, Geert
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                you should compare datasheets of the new and the old screens.
                  • 22279
                  Theres one listed on aliexpress as LTN173HT02-C01 X01 for Toshiba Qosmio X770 X870 X775 .What part number is yours it seems theres 5 different ones - C01,D02,T01,T02,X01
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • Kiberge
                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                    by Kiberge
                    HI guys!
                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                    04-22-2024, 11:28 AM
