Technika 40-270
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Technika 40-270
    Hi all what would be causing a Pitched buzzing sound,please don't laugh,doesn't disappear either high or low sound.
    What could cause this issue,nothing is connect apart from standard indoor aerial.
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: Technika 40-270
    Oh it disappears when muting lol
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Technika 40-270
      Post can be deleted thank you
      • nomoresonys
        • 12323
        • U.S.
        Re: Technika 40-270
        So nothing is wrong then??
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
        • Phil289
          Bush eled32240fhdcntd3d - no aerial signal
          by Phil289
          Hi
          Could somebody guide me as to what to check next?
          This tv has slowly become harder and harder to pick up a signal from the aerial.
          Sometimes if i leave it on long enough it will find all the channels and work great until the next cold boot.
          Ive tryed another tv in the same aerial socket and it works fine.
          Ive tryed the ‘faulty' tv in another working aerial socket and it doesn't find any channels at all.
          There's no looseness to the aerial socket on the tv and checking inside on the power board and mainboard there's nothing obvious to see - its all...
          12-02-2022, 01:54 PM
        • 1empirez
          Daikin non inverter indoor board bios
          by 1empirez
          Good day..does anyone have those indoor pcb bios? Thanks in advance
          08-27-2024, 01:25 AM
        • unimatrix93
          Technika T32HD-278-17 (VESTEL)
          by unimatrix93
          Hello everyone!
          My crappy Technika TV has a flashing red light symptom. Black screen, Voltages looks good.
          Does anyone have the EEPROM bin file for this model?
          Technika T32HD
          MB: Vestel 17MB140
          Panel: VES315WNDA
          Thank you!
          06-16-2022, 04:11 AM
        • rustinjust
          technika tv, 32 inch,capacitor replacement question, useful advice needed
          by rustinjust
          I have a technika tv, 32 inch, around 10 years or so in age and last night when watching tv i heard a hissing sound and the next thing i saw smoke coming out the back of the tv, i instantly unplugged the tv. I took the back off tv to expose power board, then plugged in tv and saw smoke coming out of a capacitor, i will try and attach a photo below, see below for attachments of board and cap, and keep reading, maybe you can advise ?
          The cap says on it: 105kj450mff4. This doesn't mean a lot to me as i'm an amateur when it comes to electronics, though i've undertaken some repairs such...
          06-07-2022, 08:29 AM
