HP 850 G2 dead no led no fan
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hy, this laptop no longer gives signs of life, pressing the button does not light the leds or the fan. the jack is intact and there is 19v on the first components.
    A part number HP is SPS 799513-001 it's a Intel I7
  • peste
    • Dec 2016
    • 13581
    • ROMANIA
    Re: HP 850 G2 dead no led no fan
    you have 3.3v, but 5v..you have voltage on the bios chip .. give more details.
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      there is no voltage on the bios chip or spi, on the battery there is 1.2V while on some components there are 1.5v
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        when you connect the power adapter do you see light that the battery is charging.. any details how it all began do you own this laptop .. and what are your actions.. do you re seat the ram connect external monitor..before you dismantle it....check for ALW voltage 3.3v 5.0. check the cmos battery if still in 3v range.
        Never stop LEARNING because life never stops TEACHING!
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          I don't have the diagrams, the battery is not charged and no LED lights up. every now and then I connect an external video. normal use
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            disconnect the battery and try to start the unit using the adapter...check all the coils for voltages.. and post it here...bios ic must have a 3v vcc to function correctly.. check also the rtc bios battery.. disconnect the ram then power on,,
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              if you cant see voltage in the coils try to look for short circuit to ground..check the 19 power rail..3.3v alw and 5v alw.. those voltages must be present to power on the unit..
                • 21874
                Check the long part number on the board,if its 6050A2637901-MB-A02 then here`s the schematic
                https://www.badcaps.net/forum/showthread.php?t=85724
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  thanks,,
                  • Fabbrone
                    • Jun 2015
                    • 158
                    • italy
                    Grazie
                    • Fabbrone
                      • Jun 2015
                      • 158
                      • italy
                      The plate code is that, there is a short on the L6150 5V coil
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        try to check mosfets connected to this coil..
                        • Fabbrone
                          • Jun 2015
                          • 158
                          • italy
                          there are inconsistencies between the diagram and the mainboard do not match the components
                          • redbaron1007
                            Liquid damaged macbook A1466 fan spins, but doesn't turn on.
                            by redbaron1007
                            I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
                            10-24-2024, 05:45 PM
                          • tuankietkiet
                            Dead Dell Inspiron 14r N4010 (Used to beeps 3 times but no longer do)
                            by tuankietkiet
                            When plugged in (no battery installed), the battery light on the motherboard lights up and then turn off. When powering on, the same and light and the power button also light up in a white color but no output on the display. It stayed like that for a few seconds before shutting down. I also seem to ruined a connector that connects to the WLAN, 2 USB and audio board, the same board also have a melted 2062A IC. I will post pictures in the reply section
                            05-11-2024, 04:40 AM
                          • ShadowAi12
                            ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                            by ShadowAi12
                            I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                            • The board enters a "ready to power on" state after plugging in the PSU.
                            • Pressing the power button increases power draw.
                            • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                            Measurements:
                            (taken after pressing the power button, while the board is attempting to start)
                            • H_SKTOOC#
                            06-11-2025, 01:05 PM
                          • araxnido
                            Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                            by araxnido
                            Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                            When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                            06-10-2025, 09:26 PM
