Anyone Work on Neato Robotic Vacuums or Know about Lidar?
  • braxton
    • Nov 2009
    • 146
    I have a Neato Botvac D80 series robotic vacuum with an error 3000 (problem with the lidar sensing unit). Basically, when the lidar unit starts to spin up, it doesn't reach the proper speed but spins fast and then slow and then speeds up and then slows down etc. until it errors out.
    Because i have a spare working unit, I was able to track the problem to a small simple board at the base of the lidar unit.
    I will attach some photos shortly.
  • braxton
    • Nov 2009
    • 146
    Re: Anyone Work on Neato Robotic Vacuums or Know about Lidar?
    A few photos:
    • braxton
      • Nov 2009
      • 146
      The 4 wires go to the main board. Power, ground, Rx and Tx.
      Where to go from here??
        Since you do have working board for comparison:
        1) Do you have the oscilloscope to check Rx and Tx signals?
        2) You can also check Voltages of IC U1.
        • braxton
          • Nov 2009
          • 146
          i do not have an oscilloscope but I can try to check voltages of the one chip.
          I think U1 is a Texas Instruments LM393A Dual Comparator chip.
          • braxton
            • Nov 2009
            • 146
            I also think this defective board is somehow supposed to wirelessly power additional boards on the top side of the lidar unit, as well as wirelessly communicate with the other board(s).
            See
            http://blog.avrnoob.com/2015/08/neat...-1-ir.html?m=1
            • braxton
              • Nov 2009
              • 146
              It looks like the board gets the 5V signal, which powers the U1 chip and also powers the coil. I believe the coil is used to inductively power the top board, which contains the laser etc. All seems good there.
              I also notice that D4 glows red but D2 does not light up at all.
              Is it supposed to?
              I suspect that D2 and D4 communicate wirelessly with corresponding Rx and Tx diodes on the upper lidar board.
              Is it possible that D2 is bad (how would I test it?) and if so what would be a suitable replacement?
                Is it supposed to?
                Well you do have working board so you can see what D4 and D2 should behave, one of them may be emitter (D4) and another one is for receiver (D2). What kind of cover is installed on top of those two diodes?
                The inductor output may be connected to the white connector. Where does it goes to? LIDAR motor assembly?
                Q2, 3, 5, and 6 look to be for driving LIDAR motor.
                How about showing the other boards and how they are connected together?
                • braxton
                  • Nov 2009
                  • 146
                  This link has pics of the other top boards and likely explains everything better than I could:
                  http://blog.avrnoob.com/2015/09/neat...t-2-lidar.html
                  • braxton
                    • Nov 2009
                    • 146
                    I think Q9 is bad. Can anyone help me identify it.
                      Why do you think it is bad since you do not know what it is? Did you compare the readings, Voltage and junctions, to the working board?
                      BTW, that link in your post #9 is useless, it does not show how all the boards are connected together. I guess you are not going to provide the info as requested. Good luck, I'm out.
                      K38 = BSS138
                      https://cdn.badcaps-static.com/pdfs/...e0c2c6e155.pdf
                      • braxton
                        • Nov 2009
                        • 146
                        That link (parts 1 and 2) does indeed explain the connections to all the different boards in the text. The bottom board powers the top boards wirelessly and communicates wirelessly as well.
                        The part is bad because it is shorted across the 2 pins on the same side (not the case on the working board)
                        The part in question links directly to the brown wire (which is either Rx or Tx), which in turn links to the main robot board.
                        • braxton
                          • Nov 2009
                          • 146
                          I've shown the connections to the transistor/mosfet.
                          The pin labelled G is ground. This circuit connects to D4 which transmits or receives IR signals from the top board.
                            Remove it and test it off the board to make sure.
                            • braxton
                              • Nov 2009
                              • 146
                              Yes I did that already. Those two pins on the mosfet are shorted (actually 40 ohms resistance). The 3 connections on the board are not.
                                The pins are Gate and Source, it may nave been damaged by static discharge. Be careful when handling MOSFET, they are easily damaged by static discharge.
                                • braxton
                                  • Nov 2009
                                  • 146
                                  Thanks for making me aware of the static sensitivity of this mosfet.
                                  • ngml
                                    Repair of an LG split AC system indoor unit PCB
                                    by ngml
                                    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                    This indicates an error in the communication between the outdoor and the indoor unit.
                                    The outdoor unit is fine, so the problem is the indoor PCB.
                                    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                    Does anybody have the schematics of this board,...
                                    02-01-2025, 12:55 PM
                                  • CoinCoin88
                                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                    by CoinCoin88
                                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                    Yesterday, 03:36 AM
                                  • DrDos
                                    Unit runs but no speaker output kenwood KR-6030
                                    by DrDos
                                    I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                    09-14-2025, 09:57 PM
                                  • nobbnobb1
                                    Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                    by nobbnobb1
                                    Hi guys,
                                    Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                    When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                    02-03-2022, 11:14 AM
                                  • Gjackson
                                    Air-conditioning unit power supply failing to power up
                                    by Gjackson
                                    Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                    01-08-2022, 09:24 AM
