APC BackUPS LS-500 Schematics?
  • cook
    Quiet observer
    • May 2010
    • 100
    Asking for schematic and/or boardview for APC BackUPS LS-500.
    Board number: 640-0236J-13
    • Jul 2011
    • 6069
    Re: APC BackUPS LS-500 Schematics?
    Can you please post some pictures of the board front and back so can read part numbers
    We might be able help you fix it
    • cook
      Quiet observer
      • May 2010
      • 100
      The pictures are below. I tried to get the best resolution I could.
      From left to right..
      #1. Top Left of the board
      #2. Top Right
      #3. Bottom side of #1
      #4. Bottom side of #2
      • cook
        Quiet observer
        • May 2010
        • 100
        Here is the problem I am working on with this UPS. Sometimes, only for a second or 2, the 'bad battery' light flash and it will beep. I have tried different batteries, and it still does it. I have tried a brand new battery, and it still does it. It may show the fault once every 5 minutes, sometimes more frequently, sometimes less frequently. It does this when something is plugged into it, and when nothing is plugged into it. When the UPS is running I am getting a good voltage at the battery, 13.69 volts. When the new battery is unplugged from the UPS, it reads 13.7 volts. The new battery has charged for 24 hours.
          • Jul 2011
          • 6069
          Will this battery backup work with a 100 watt incandescent light bulb load with no 110 line voltage hooked up
          It should turn if you hold power on button for about 5 second or so ———> if not try this hook it up 110 volt line voltage then after it does it self check if has one then unplug it from the wall dose the light bulb stay light if not then you have a problem with the power switch over circuit
          • cook
            Quiet observer
            • May 2010
            • 100
            Yes, it works fine with a 100W light bulb running on the battery. I could see the light pulse just slightly, but it ran the bulb just fine. I ran it a few minutes.
              • Jul 2011
              • 6069
              Okay
              While you had the 100 watt bulb running on battery power did the low battery warning flash on or did even come on while you were doing this test
              Look at the fault light wiring and trace where it goes on the circuit board until you reach a ic chip or some type of device and look up the device to see what it does then see if there is a capacitor near that device that goes to that device and replace them if there is more one capacitor
              also trace the battery terminals back to some type of voltage monitor circuit on this board and if you find any capacitor replace them as well but before you buy anything mark where these capacitor are on the board
                How many Watts is your actual load that you were having problem with? Notes: I am not talking about the 100W bulb.
                You can also add another 100W load to see what happen.
                • cook
                  Quiet observer
                  • May 2010
                  • 100
                  Okay
                  The 'replace battery' light did not come on during the test.
                  I will get a list of the ICs on the board and post them in order to help me figure out what chip might be responsible for the 'Battery Replace' alarm. I will get that together later today. Knowing which chip might be responsible for that will give me 2 ways to track down the capacitors on the circuit -- tracing back from the LED and tracing from the IC.
                  • cook
                    Quiet observer
                    • May 2010
                    • 100
                    The 'Replace Battery' alarm comes on with a load, and without any load.
                    I will find a more items to plug into it and run it to see if anything changes. I will run it plugged in to AC, and running on the battery.
                    • cook
                      Quiet observer
                      • May 2010
                      • 100
                      Chips On The Board
                      APC BackUPS LS-500 / Model BP500UC / Board number: 640-0236J-13
                      Below are the ICs on the board. I looked up each one and I listed what I found about them.
                      Which ones might be part of the circuit that triggers the 'Replace Battery' alert? I am thinking it is one or both of the 'LMxxx' chips maybe?
                      BIG CHIP
                      The largest chip has a white APC sticker
                      on top of it listing it is for a 350/500/700
                      unit, along with a version number. So I am not
                      sure what that is. Maybe ROM?
                      360-2040B
                      UEWJ0414
                      What is this?
                      93LC46B
                      EEPROM
                      SN74HC595N
                      8-bit, serial in, parallel out shift register
                      Is this for the USB connection?
                      LM393N
                      Two independent voltage comparators
                      LM324AN
                      Four independent operational amplifiers (op amp)
                      4N25
                      Single channel phototransistor coupler
                        • Jul 2011
                        • 6069
                        Originally posted by cook
                        Chips On The Board
                        BIG CHIP
                        sure what that is. Maybe ROM? ( if any pin goes any devices below that I made comments about then replace all capacitors that connects to any pin on this device )
                        360-2040B
                        UEWJ0414
                        What is this? ( does any pin of this chip go to any of following devices below if they do then replace all around this chip
                        93LC46B
                        EEPROM. ————
                        SN74HC595N
                        LM393N
                        Two independent voltage comparators. ( Replace capacitors if they go to any pins on this chip )
                        LM324AN
                        Four independent operational amplifiers (op amp) ( Replace any capacitor that goes any pin to this chip )
                        4N25
                        Single channel phototransistor coupler ( most important capacitor to change if any pin has a capacitor to it )
                        See above for my comments
                          • Jul 2011
                          • 6069
                          I was afraid of this that this might have been the case thanks for sharing this information
                          • cook
                            Quiet observer
                            • May 2010
                            • 100
                            I ran it connected to AC, running these lights: 40 watt incandescent, 60 watt incandescent, and a 150 watt halogen. The 'replace battery' LED came on briefly about 2 minutes into the test, then 5 minutes later, then 3 minutes later. Then I turned off the power to the AC, and it switched to battery. It runs fine on battery and the 'replace battery' LED does not go on. I ran it about 5 minutes like this and then stopped the test.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8340
                              Got across this schematic today while doing backups. Hope this helps.
                              BTW: on your second picture there are 2 relays and 2 brown capacitors. The top brown capacitor looks to me bad.
                              • cook
                                Quiet observer
                                • May 2010
                                • 100
                                Thank you for the schematics!!
                                And thank you for noting that cap. I just looked closely at it, and it is has a slight depression across part of the top. It almost looks like something pushed into it because the metal on the top appears to have a small scratch or depression in the metal like something sharp pushed it in. It might even have a tiny hole in it, but I am not positive. I will certainly test that one further to see how it looks. It is a KMG Cap, ie. Nippon Chemi-Con
                                  • Jul 2011
                                  • 6069
                                  The circuit diagram that you posted I only find one relay not two of them and I look for it for a while
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8340
                                    I know that this schematic I posted above isn't the exact match, but it should be good enough to give an idea what is going on.
                                    For me, I'd ESR the sh*t out of them caps and replace them. I've had a run in with my small SMT a few years back, it turned itself off all the time.
                                    https://www.badcaps.net/forum/showthread.php?t=66277
                                    I'd change the two brown caps, the 2 black caps next to it and C51 and retest.
                                      • Jul 2011
                                      • 6069
                                      I would recommend this as well I more or less said the same thing earlier
                                      • cook
                                        Quiet observer
                                        • May 2010
                                        • 100
                                        sam_sam_sam,
                                        I am currently identifying what capacitors are connected to the pins on the chips.
                                        Am I only interested in the caps that are first component I find on the trace, or should I be going further down the trace through a few components?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
