acer aspire 4752
  • String2016
    • Nov 2015
    • 2238
    • philippines
    acer aspire 4752
    Anyone can help me on this acer aspire 4752 JE40 HR MB 10267-4. the problem is all voltages are present but cannot power on, i notice that if i touch the pin 4
    ON PWRCN1 3.3v bluelight comes if i remove blue light gone, and also notice the mosfet connected to same with pin 4, pin 4 have 3.3v pin3 have 3.3v
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: acer aspire 4752
    anyone please help
    • Techtiger
      • Oct 2014
      • 1602
      • france
      bad solder joints may be the cause does the voltage drops #power button ?
      • String2016
        • Nov 2015
        • 2238
        • philippines
        the voltages is not droping it stays on 3.4v but goes up on .42 to up something.I noticed also that when i rest the board for a couple of minutes it can turn on directly with no problem but unplugging and plugging back the charger it cannot turn on but voltages on pin 4 is ok
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          try to re solder it...try to test continuity..
          Never stop LEARNING because life never stops TEACHING!
          • String2016
            • Nov 2015
            • 2238
            • philippines
            already did resolder same results I noticed once it cannot turn when you touch the 3pin mosfet 1 and 3 turn on lights blue comes up but when release lights gone
            • Techtiger
              • Oct 2014
              • 1602
              • france
              heat the MB with hot air gun near charging IC & 3&5V regulate & the first 2 fets for any results
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                here is the schematics try to trace it..
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  @techtiger i tried your idea reheat the chip and mosfet still the same it turns on when laptop is on rest but after plugging out and plugged in again cannot turn on
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    did you check the ram if its ok... did you reflash the bios? all voltage rails are present? try to reflash the bios chip.. try also to check the rtc bios battery.. is the switch button connected to the keyboard? if so try to disconnect the keyboard and connect the power adapter if it still powers on..
                    here is the bios dump
                    https://www.badcaps.net/forum/attach...4&d=1464192697
                      • 21412
                      JE40 HR boardview - https://www.badcaps.net/forum/showthread.php?p=972108
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        @duranitron ram is ok because once it turns on display comes and you can used no problem, once you unplugged the charger and plugged again it cannot turn on, I need to wait for a couple of minutes to turn again, all voltages are present, i did not try to flash the bios
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          tried flashing the bios same result
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            is the fet pu3802 ? when you touch BLUE light comes on
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              @techtiger the mosfet is Q6801 Which touching it bluelight comes but fan is not spinning
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                anyone can help on this please
                                  • 21412
                                  Remove the ribbon cable from PWRCN1, short pin 3 to GND, see if the board powers up.
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    @smdflea already tried that nothing happens but if i short this 3pin mosfet blue light comes up fan not spinning but release it blue light gone
                                      • 21412
                                      Its only for the LED if you think its a problem remove or replace the mosfet. With no power check theres no continuity between PWRCN1 pins 3 and 4.
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        I tried replacing that mosfet still the same issue
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
