Hisense 50K360N screen going on and off when changing between picture modes
  • jmandawg
    • Jul 2020
    • 42
    I have a Hisense 50K360N when switching between picture modes, certain modes will cause the screen to start flashing to a black screen every second. Changing the adaptive backlight setting or chainging the backlight level from 100 to 99 will make it stop, i can then set it back to 100 and it will be fine. But when i switch between the picture modes it happens again.
    Any ideas? I watch a few youtube vids and it seems like it might be the power supply or backlight. I did take it apart and look at the caps and they all looked fine.
    Any suggetions?
    Thanks.
  • nomoresonys
    • 12214
    • U.S.
    Re: Hisense 50K360N screen going on and off when changing between picture modes
    You should not run the backlight level at 100, should set it to as low as you can tolerate the display to keep the backlights from burning out, it will extend their life as well.
      Yep, turn down the backlights level to as low as possible on all modes and on all inputs, and recheck them again after turning the TV of and then back on to make sure the settings stay. It sounds like the LED's are failing at full drive.
      • jmandawg
        • Jul 2020
        • 42
        thanks for the help guys. Unfortunately if you try to modify one of the presets, it copies that preset into the custom settings, so the named presets won't save changes.
        Luckly i found in the service menu there is an option for max backlight, i changed this from 255 to 200 issues seems resolved for now.
        Thanks again.
        • nomoresonys
          • 12214
          • U.S.
          Yep, you need to do it from the service menu on some tvs, thanks for feedback.
          • adamp91gvm
            hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
            by adamp91gvm
            as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
            09-10-2025, 12:13 PM
          • petersor
            Hisense 58R6E3 Backlight/No Picture Repaired
            by petersor
            Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
            06-07-2024, 04:16 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • TVGuy419
            Hisense 75R6E3 No Picture
            by TVGuy419
            I replaced the backlights on this Hisense TV and the LEDs were showing on certain images. Drove me nuts, so pulled it apart, got new LEDs and put it back together. Now I don't have a picture. TV came apart very easily both times and I was very carful with the panel. I've replaced all the boards for good measure and still have the same issue. Unhooking either side of TCON board still gives me a blank screen with backlights and sound. Is it really possible the panel is junk just from taking it off with suction cups and gently placing it back in place?
            11-09-2023, 06:38 AM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
