Dell 960 Memory Allocation
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    I've seen a few Dell's do this....but here's the issue. This is a Optiplex 960. Note the RAM amount in the image below:
    I ASSumed this 'usable' amount was taking into consideration memory grabbed by the onboard GPU....ok, no biggie. Here's where it gets goofy... I've put a PCIe GPU in this system, which presumably disables the onboard (no longer shows in device manager)...why has the memory not been released; IE the full 4GB usable? I have an Optiplex 980 doing the same thing except with 8gb; 7.87gb usable....very different platforms. BIOS's are latest/current.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Dell 960 Memory Allocation
    Disclaimer: I know nothing of how PC's work -- but a shitload about processors, in general!
    [Presumably, you are running a 64b OS? Otherwise, you k now the total memory space will be limited to 4G... which must include the GPU memory]
    If the CPU (chip) in the device can only address 4GB of PHYSICAL memory (i.e., if there are only 32 address lines leaving the processor), AND if the GPUs memory ends up directly mapped into the CPUs physical address space, then it consumes a portion of the ADDRESS space even if there exists other physical memory available (it "overlays" that memory).
    You can test this by removing the GPU and installing some generic video adapter (with less memory) and manually disabling the onboard to see what it reports as usable in that configuration.
    In the second machine, it could be that it has the capacity to address 8GB of physical memory and the GPUs memory is overlaying some portion of that.
    [Again, reread my disclaimer]
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      Well, good thing is that you're running 64-bit Win7, so at least that takes the address space limitation out of the picture.
      It looks like about 128MB is being reserved for some reason. Usually it depends on the BIOS and firmware memory mapping, sometimes SMM eats up RAM, sometimes BIOS shadow eats the RAM. As RAM amounts go up, that 128MB won't get "missed" with the RAM used up by the OS with stuff like pagetables,... so much for fleecing us.
      Would be nice to get E820 data from the machine to know the exact memory map...
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        No, it only takes the OS's address space constraints out of the picture. If only 32 address lines are bonded out of the chip, then the limitation would persist in the HARDWARE.
        I assume that such bondout options are common (cost savings and feature restrictions) cuz, otherwise, why have an *8G* limit on a machine?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Some boards have different memory remap options in the BIOS, I guess for the limited BIOS in a Dell that is not an option though.
          Here is a very lengthy MS article I found, it goes into quite some details about what can cause it.
          My bet would still be that the built in graphics steals it, since it is such a nice round number missing.
          Their specific mention of a Intel 975X is interesting though, I guess a Google search for your chipset might reveal something?
          https://support.microsoft.com/en-us/...on-windows-7-b
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It does not work that way, bus widths above 8-bit CPU's are pretty arbitrary.
            64-bit vs 32-bit is a logic thing, not hardware.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              ...as per my original post & thought....I just figured the BIOS would let it go when the onboard GPU disables. Strange but not the end of the world.
              Team : 49813
              Join in!!
              Team Stats
              • RJARRRPCGP
                • Jul 2004
                • 6304
                It's only 4 GB of RAM, FFS and it's acting like it's 32-bit!
                Core 2, definitely supports at least 8 GB, if not more!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8696
                  Actually a 32-bit processor, chipset that doesn't really support 4GB RAM, or 32-bit OS without PAE turned on running on 4GB RAM should show up near 3372MB RAM, this is even more than 512MB off from 4GB, so this is a different issue.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Yes, but my point was more that crap BIOS often have these limitations.
                    The memory does need to be remapped.
                    And older chipsets like that often have a 36-bit address bus in the memory controller.
                    That means a max of 8GB memory, but that includes stuff like the PCI address space, and memory on a dedicated GPU.
                    It all has to fit into the same address space...
                    Newer chipsets do not have these limitations.
                    And no, in your case it is of course not the 36-bit limitation.
                    But still, try it with 8GB and see what happens, it might reveal something.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      For DDR2, you're lucky to get 8 GB when you raise VDIMM to 1.90V to run them at 333 Mhz (666/667) Because with consumer RAM, usually need to mix sticks and use all 4 slots!
                      Good luck with getting more than 8 GB of RAM with most DDR2 platforms.....
                      Arc A770 16 GB
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3264
                        • Singapore
                        i think ratdude or dan87 had this problem before several years ago and they posted about it here too. my stand is still the same back then as it is now. i think its the 32-bit pci address space problem like with the gart table like per hansson said. thats why the memory hole still sticks even with a discrete gpu. some asus boards have a bios option to remap the 32-bit pci address space above 4gb to fix this type of issue and have the full 4gb usable, so its dell's crap bios at work.
                        i also did some memory benchmarking with the pci address space remapped. having the memory remap feature ON made memory latency slower by 1 ns. complete non-issue in real world applications and not noticeable at all. what is noticeable is the system being faster with more ram available when using memory hungry programs that gobble ram like skittles... just posting this for informational purposes in case someone is curious if the feature affects memory performance and why would u turn it off? lol.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          I have plenty of DDR2 rigs running well above 8gb ram.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            Huh? Who mentioned 8-bit CPUs?
                            And, 64 vs 32b is definitely a "hardware thing". A 32b OS is limited to a 32b logical address space simply because it (by definition) can't deal with pointers larger than 32b.
                            As an example, i3 westmere can only access 8G while sandybridge can do 16G and (most) skylakes can do 64G (though some are limited to 32G). The software doesn't "see" any difference between the "address space" available to each; rather, the hardware imposes those limitations.
                            They're all 64b processors. The LOGICAL address space in each of them is the same -- 2^64 bytes. Yet, if I try to access 195 billion different physical addresses, I will be sorely disappointed in each case -- despite the fact that the physical address space is 1,000,000,000 times larger than my "needs". Software (bare metal) needs to know the characteristics of the actual hosting processor AT RUN TIME in order to know how big it's actual physical address space is, for THIS processor.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              it might actually be a sucky bios that still allocates 128M for video
                              or check your cmos to init on PCI-E and not IGP. Or see if it still is using the IGP in combination with the GPU for some reason
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                I inferred (perhaps incorrectly) that you meant physical address lines from your first post:
                                "If only 32 address lines are bonded out of the chip, then the limitation would persist in the HARDWARE."
                                That is why I made the example to an 8-bit CPU, because it is easy to visualize the 8 address lines in it.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  I tried clearing the CMOS on the 960 & 980...no avail....still sucks up that 128mb needlessly. On a 380, when adding a PCIe GPU, the 128mb RAM is released by the BIOS, full amount (4 or 8gb) is available to the OS.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    plug a separate monitor in the IGP while it's on. If it outputs to the monitor, then the IGP is still enabled. might not be able to fully turn it off. Maybe there is a multi-monitor option that needs to be disabled, and the option to disable it might not be there
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      That's because you have "server-class" and "pro-workstation-class" motherboards and thus, they can use that semi-ad-hoc-DDR2-SDRAM. (With ECC and buffering or the like)
                                      Regular-consumer-class-DDR2-SDRAM=There's no more than 2 GB per stick or they are rare!
                                      Arc A770 16 GB
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        When chipsets of that era in that market don't support more than 8gb @ 4 slots w/ 2gb modules, was there really any demand for larger modules?
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • lalle-
                                          Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                          by lalle-
                                          Hello!
                                          I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                          [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                          I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                          The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                          I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                          08-11-2024, 02:01 PM
                                          Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:21 AM
                                        • Themi
                                          Dell XPS 13 9310 2 amber 4 white memory failure
                                          by Themi
                                          I have this laptop a dell XPS 13 9310
                                          Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                                          I believe this is the spec from using micron tool to decode marking
                                          Images of the ram
                                          I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                                          Another...
                                          11-24-2024, 09:06 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
