DELL Optiplex 740 - Need bios please no original
    Greetings,
    i have a damaged Dell Optiplex 740 which crashed during bios update and needs now to program the chip.
    I downloaded bios from Dell but it is compressed in exe file and did not manage how to extract according to some methods that i found here......
    Does anyone have a bin file or know how i can find it?
    My model is Dell Optiplex 740 and M/B CN-OPY127-70821-6AR-90QX REV A02
    Thanks in advance
    Re: DELL Optiplex 740 - Need bios please no original
    Try this file, there are two BIOS inside 4Mbit and 8Mbit
    Depends on what BIOS chip / version you have.
    This is extracted from O740-222.exe using HEX editor.
    This is untested...
    Source: http://ftp.dell.com/FOLDER51375M/1/O740-222.EXE
    MD5 of O740-222.EXE: 2d987278b92f148404f656395b4bcee4
      This is untested...
      Dear Per, thank you very much for your input. I just programmed it and works fine i have managed to power on the machine. Be well my friend
        You are welcome, was it the 4Mbit or 8Mbit file you used? (To know which one is tested good now)
        Also when you have the ability can you check if it is SLIC 2.1 or SLIC 2.0 using SLIC Toolkit from mydigitallife?
          Hi friend, it was the small one the 512kb.... i will check tomorrow for the SLIC if the machine is still at the store and let you know my friend....
            Greetings Per, i attached you the SLIC output
            Have a good day
