What is this part??
  • albaraa12
    • Dec 2018
    • 9
    • jordan
    What is this part??
    hello all,
    I have Toshiba tecra Z40-A1241 laptop, there is a picture on it's screen but with no light on the screen, I test the screen on another laptop and it works perfectly,
    and test the video cable and it also works. As shown in below picture I want to know what this white part(it has a 322 number on it's surface)? fuse or something else? I can't find laptop schematics.
    please help me.
  • Bonzas
    • 472
    • Indonesia
    Re: What is this part??
    i think it's crystal
    • albaraa12
      • Dec 2018
      • 9
      • jordan
      Can remove it and connect directly? I can not find a replacement
      • lapfix
        • Mar 2020
        • 2757
        • my workshop
        If it's a crystal than you can't
        but i think it s not a crystal...you have a picture but no backlight
        with lvds cable connected, take all the measurements and post it here
        if you have a schemayics post it
        • albaraa12
          • Dec 2018
          • 9
          • jordan
          Unfortunately, I don't have schematics. On one of it's sides there is 19.0 volts and on the other side there is no volt.
          • Bonzas
            • 472
            • Indonesia
            no you can't, it won't work if you connect directly/jumper.
            what is your board code ?
            • albaraa12
              • Dec 2018
              • 9
              • jordan
              What is your board code ?
              • albaraa12
                • Dec 2018
                • 9
                • jordan
                this is the part under microscope
                and this after removing silicone on it
                • albaraa12
                  • Dec 2018
                  • 9
                  • jordan
                  Motherboard Code: toshiba famxsys a3660a
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    the part is marked as 322 and it cant be crystal. Let the part remain removed and power on the mb and check voltage on both pads of that part. Its likely to be a fuse but first check voltage reading.
                    • petehall347
                      • Jan 2015
                      • 4440
                      • United Kingdom
                      measure ohms across the good one .
                      • albaraa12
                        • Dec 2018
                        • 9
                        • jordan
                        Thank you, it is a fuse I connect it directly and the screen works !!
                        • Bonzas
                          • 472
                          • Indonesia
                          i'm sorry for the wrong answer from, since i don't have schematic or boardview and i can't find it, i can't make sure what was that. I said it crystal cause i found on some board have crystal like that near lvds con and i don't read clearly your post that said it was marking part. Glad to hear you solved your problem
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            @martha, Nothing to be sorry-we all commit mistakes but lets learn from our mistakes.
                            • albaraa12
                              • Dec 2018
                              • 9
                              • jordan
                              Thank you all for your help and replies
