Yamahaha RX-V679 DC PRT High
  • peterwheat
    • Aug 2020
    • 18
    Hey all,
    I have a Yamaha RX-V679 that is entering protection mode after a few seconds of turning on. Shows "DC PRT 77H" error when I disable the auto protection.
    All speaker terminals read ~0.4 volts across, except for the surrounds, which read 0 volts for right and ~0.9 volts on the left, which increases until the receiver kicks off. I'm thinking this is my problem child.
    I took it apart and started testing the main output transistors, and didn't see anything blown open (I did this without desoldering, however I compared to nextdoor channel and all were very similar). The attached picture shows the transistors. Attached picture shows them.
    Question is, what is my next step for testing?
    Thank you for your help!
    Service manual is located here, too big to attach
    https://drive.google.com/file/d/1VtI...ew?usp=sharing
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Yamahaha RX-V679 DC PRT High
    most likely the differential transistors . is there no dc offset adjusters ?
    • peterwheat
      • Aug 2020
      • 18
      Which ones are those?
      Not that I am aware of, but frankly I'm not that knowledgeable on receiver electronics.
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        have you got a schematic ?
        • peterwheat
          • Aug 2020
          • 18
          Update:
          I put things back together so I could reverify some voltages. I checked all the active speaker terminals for voltage again, and everything that's active is reading about 400 mV, with close to 0 on the non active channels. I had a speaker hooked up to one of them, and it sounded very distorted unless it was at a whisper like loudness.
          • peterwheat
            • Aug 2020
            • 18
            Schematic should be in the service manual above, I can attach the main board pdf possibly?
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              need to check the power supply first . if thats wrong it will never work properly
              • peterwheat
                • Aug 2020
                • 18
                Should I just be checking voltages coming out of the power supply then?
                • petehall347
                  • Jan 2015
                  • 4440
                  • United Kingdom
                  yes check those first .
                  • peterwheat
                    • Aug 2020
                    • 18
                    Checked these voltages, all correct. (within 5% or so)
                    • petehall347
                      • Jan 2015
                      • 4440
                      • United Kingdom
                      look for the -12.4v rail .
                      • peterwheat
                        • Aug 2020
                        • 18
                        On the main board, correct?
                        • petehall347
                          • Jan 2015
                          • 4440
                          • United Kingdom
                          yes .if you look at the input to the amps on the schematic its there .
                          • petehall347
                            • Jan 2015
                            • 4440
                            • United Kingdom
                            also measure at for example Q1002 base .should be 0v ..i ask this because offsets are high when active . might be stray voltage getting in here .
                            i have a feeling the fault might be the input switching chips .
                            lets see those voltages first though before i get carried away too much .
                            • peterwheat
                              • Aug 2020
                              • 18
                              Reads at -12.2V
                              • peterwheat
                                • Aug 2020
                                • 18
                                Q1002 is in a Y shape, from the bottom of main board
                                -0.45V 0V
                                56.58V
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  • United Kingdom
                                  what does it measure when that channel inactive ? like not selected .
                                    Originally posted by peterwheat
                                    Hey all,
                                    So the Surround Left is the only one that has output offset that goes too high after a while then the receiver goes into output high DC shut down?
                                    Is it Surround Left? Or is it Surround Back Left? I ask because you were asked to check Q1002 which is for Surround Back Left, not Surround Left. Please Clarify as to which Left channel is bad.
                                    Below is for Surround Left checking:
                                    Once it goes into shutdown,what DCV do you get on jumper J245 (close to Surround Left output inductor L6, see service manual PDF page 118)?
                                    Is it Positive or Negative Voltage reading with ref to GND?
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      • United Kingdom
                                      i only used Q1002 as an example .. its fairly straightforward looking at the schematic .
                                      from what i read offsets are only high when channel is active . and not just one channel . 400mv offset .
                                      i haven't studied whether it cuts the speaker off or mutes the input when not selected .
                                      • peterwheat
                                        • Aug 2020
                                        • 18
                                        SR: 0.353
                                        SL: 0.302
                                        C: 0.300
                                        FR: 0.358
                                        FL: 0.305
                                        SBR: -0.009
                                        SBL: 0.814
                                        Those measurements are with all channels selected.
                                        waiting on it to kick off so I can measure the jumper now.
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • hs5424
                                          Dynacord powermate 1600 protection on.
                                          by hs5424
                                          My first post from an old timer.
                                          I see here that this is a common problem with these Dynacord powered mixers. When the unit is powered on the protect led comes on straight away. I immediately checked the O/P transistors and removed them from the board (heat sink paste dried out so not a waste of time). All checked out OK. The main 80v + and - OK. However when I check for voltage on the inductors going to the speakers (o/p transistors removed) I found -30v on L501 which is the right side channel. The left side inductor shows zero volts. Am I correct in thinking that the right side is the...
                                          06-20-2025, 04:10 AM
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
