Esonic H61FEL-U ES BIOS DUMP
  • imparator463
    gimsis
    • Dec 2015
    • 20
    • türkiye
    Esonic H61FEL-U ES Bıos dump need
  • Dreamcatcher
    • Aug 2020
    • 2
    • Uk
    Re: Esonic H61FEL-U ES BIOS DUMP
    Originally posted by Dreamcatcher
    try it
    try
    • notserforumlar
      • Oct 2016
      • 12
      • midilli
      thanskss, worked
      • Ghost18_07
        Zakaria
        • Mar 2018
        • 81
        • Algeria
        Thanks, working for me , H61FEL-U ES REV:5.0
        • ahemedd32
          • May 2022
          • 4
          • algerie
          bios update h61fel -u es
          hello
          I am looking for a recent bios update for esonic Esonic H61FEL-u ES
          THANK'S
          • satishkumar
            • Sep 2015
            • 164
            • India
            Re: bios update h61fel -u es
            Originally posted by ahemedd32
            hello
            THANK'S
            https://www.badcaps.net/forum/showthread.php?t=88035
            • ahemedd32
              • May 2022
              • 4
              • algerie
              thank you
              but I have already tried this version and it is old
              does not recognize HDMI Port and 4gb memory modules
              I'm looking for a newer version
              • satishkumar
                • Sep 2015
                • 164
                • India
                thank you
                try this one
                • ahemedd32
                  • May 2022
                  • 4
                  • algerie
                  Originally posted by satishkumar
                  try this one
                  works very well thank you
                  • whitevolf
                    • Feb 2014
                    • 123
                    • TÜRKİYE
                    thanks
                    • appiend96
                      • May 2022
                      • 6
                      • indonesia
                      try this one
                      work in me... tks
                      • see1001
                        elo
                        • Dec 2015
                        • 39
                        • turkey
                        try this one
                        thanks
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Citymin
                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                          by Citymin
                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                          The charging red LED lights up, but the charging screen doesn't show any indication.
                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                          (I've tried removing the battery and resetting the device, but the issue persists.)
                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • DynaxSC
                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                          by DynaxSC
                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                          11-17-2023, 10:56 AM
                        • greelidd
                          K6604J Vivobook RTX 4070 BIOS Dump Request
                          by greelidd
                          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                          09-01-2025, 06:14 PM
