dell Inspiron 3581 EDI72 LA-G714P
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    Hi for all,
    any one can help me with bios for this board : EDI72 LA-G714P
    service Tag : 8B8T1W2
    my original file and EXE from official website are in the attached files
    thanks in advance
  • peste
    • Dec 2016
    • 13562
    • ROMANIA
    Re: dell Inspiron 3581 EDI72 LA-G714P
    Originally posted by sourcebf
    Hi for all,
    thanks in advance
    try..
    • sourcebf
      • Jul 2016
      • 433
      • N/A
      Originally posted by peste
      try..
      thanks bro but with this dump board is totally dead
      • peste
        • Dec 2016
        • 13562
        • ROMANIA
        try..
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          try..
          thanks a lot my friend for your time it wasn't bios issu my original dump works fine and it is an ok dump
          • kamel84
            • Feb 2016
            • 9
            • islam
            Good my bro
            • 11rob
              • Jan 2016
              • 3
              • india
              hello sir i neeed a bios which is LA-G714P
              • 11rob
                • Jan 2016
                • 3
                • india
                This is a original fife
                • Keyur
                  • Dec 2015
                  • 12
                  • India
                  • Umadbro
                    • Jul 2018
                    • 65
                    • Portugal
                    Hi, I've been given this laptop which upon plugging the charger it produces a blinking code, and it goes as follows:
                    "3 AMBER, 5 WHITE"
                    Pressing the Power Button, the machine seems to power up, as the fan spins (at a normal rate), but after a few seconds the power cuts off, and the cycle repeats.
                    Searching on Google for the blinking code for this device doesn't return any valuable information. The code is not listed on the service manual. However, I found out that for others or similar models "3 AMBER, 5 WHITE" blinking code means ''POWER RAIL FAILURE". I am going to use a schematic I found to test some power rails, as casual probing for a short didn't show any major problem with the board.
                    I also read that the problem may be correlated with an EC power controller issue, so I went ahead and did a few dumps on the W25Q128JV ic, you can find them in the attachment.
                    Please let me know of any other information I should provide.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12318
                      Originally posted by 11rob
                      this is a original fife
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12318
                        Originally posted by umadbro
                        please let me know of any other information i should provide.
                        • Umadbro
                          • Jul 2018
                          • 65
                          • Portugal
                          Originally posted by hoaca388
                          Hi, should I try to flash this dump? I tried the one on post 8 yesterday, but the machine returns with the same issue.
                          Have you seen anything wrong with my dumps? I am still not sure where the problem lies.
                          Thank you for your attention
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12318
                            I saw your dump have proplem with ME region, so i taken other Me region and chaged it.
                            • Umadbro
                              • Jul 2018
                              • 65
                              • Portugal
                              I flashed the file on post 12, multiple times, but when I put the ic back and plug the charger, the led on the jack repeats the sequence "3 AMBER, 5 WHITE", until I press power, which spins the fan for about 10 seconds, back to the led code. This time, the led indicator on the CAPSLOCK key is always on.
                              I compared it right after flashing and it was identical. I tried reading the ic after attempting to boot with it, and comparing it with your file shows differences, is it not meant to be the same as the machine didn't boot?
                              On my last verification, this was error line I got:
                              "Verification error on address: 0x000462B0, Device: 0x47, Buffer: 0xFF"
                              I looked at both files side by side and from what I could gather the differences between them goes from offset 000462B0 to 000480C0.
                              Please let me know of any other information I can provide.
                              My last dump after flash is in attachment.
                                • 21841
                                Post the service tag number thats on the case, and the motherboard part number
                                • Umadbro
                                  • Jul 2018
                                  • 65
                                  • Portugal
                                  I noticed that my first post which I copied from a thread I made doesn't include the information about the board.
                                  EDI72 LA-G714P
                                  Rev: 1.09(A00)
                                  Flash: W25Q128J
                                  Programmer: CH341A MiniProgrammer
                                  Software: NeoProgrammer 2.2.0.10
                                  • Umadbro
                                    • Jul 2018
                                    • 65
                                    • Portugal
                                    Originally posted by smdflea
                                    post the service tag number thats on the case, and the motherboard part number
                                    service tag: B91L1W2
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12318
                                      Ok, the last try.
                                      Code:
                                      [ATTACH]254011[/ATTACH]
                                      • Umadbro
                                        • Jul 2018
                                        • 65
                                        • Portugal
                                        Ok, the last try.
                                        Code:
                                        I tried "11.8.55.3510_CON_LP_C_NPDM_PRD_RGN_outimage.bin". It doesn't show any LEDs, not even the dc one. I'm going to try this one now and come back straight away.
                                          DELL Inspiron 3581 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3581 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3581 boardview and 3581 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3581...
                                          09-06-2024, 12:36 PM
                                          09-06-2024, 11:17 AM
                                          09-06-2024, 09:32 AM
