LG 50PG3000 Plasma - No Display
  • greglogan
    • Jul 2020
    • 18
    • United Kingdom
    Hi guys
    I'm having issues once more. This time with the set mentioned above. There is no display at all but I do have audio.
    All fuses have been checked and are showing continuity as good
    All Va and Vs voltages have been checked.
    I replaced a couple of very unhappy caps on the PS board and the main Y board.
    I have removed the Y buffer boards one at a time and no result. Also, when the boards were out, I checked for continuity between the ground connector and all the pins. No continuity showing, so all looks ok there.
    Am I looking at a bad panel or is there any other checks I can try? The Z-sus board mentions very high voltages at the connectors but I am getting next to no voltage showing there at all - just a couple of volts.
    Any help greatly appreciated!
    thanks
    greg.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: LG 50PG3000 Plasma - No Display
    To check for shorts on the Y-Buffer output pins, you used the floating ground, correct? Not the chassi ground pads, because that has capacitors in series and it will always measure open.
    Does it have -VY, VSCAN/VSC/VSCN and Z-BIAS/VZB matching the panel specs (panel sticker on the top region)? the logic board also has to have a green led blinking or always on at least.
    To remove more variables from the test I recommend to unplug main board even if you have sound, short the EXT_AUTO_GEN pins on the logic board and unplug the LVDS from main.
    • greglogan
      • Jul 2020
      • 18
      • United Kingdom
      Hi
      Yes, meant the floating ground. The boards were out of circuit when tested.
      The logic board has a green LED, I think it varies from blinking to static. Not sure how to check for -VY, VSCAN or VZB......but happy to try if you can point me in the right direction.
      I'll give the main board a try in the morning. Should I disconnect all cables on the main board or just the LVDS?
      thanks
      Greg.
      • R_J
        • Jun 2012
        • 9600
        Have you checked the fuse on the Z-sus board? Post some pictures of the back of the tv and the boards so we can see what we are dealing with.
        Have you checked the other threads on this model?
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          Remove the main board power cable and LVDS, the power supply turns itself on when no main board is present.
          What part number is your Y-SUS and Z-SUS? Need the EAX or EBR code to find out exactly which boards you have because I've found multiple different PCBs online, then I can point out where the VSCN -VY and VZB test points are.
          • greglogan
            • Jul 2020
            • 18
            • United Kingdom
            Hi R_J
            yeah, I've had a look at the other threads. Most with similar faults seem to point to the buffer boards. Yes, all fuses have been checked and are good.
            Pics to follow in a bit
            • greglogan
              • Jul 2020
              • 18
              • United Kingdom
              Hi Biruslapio
              part nos as follows:
              Y-SUS EAX39647101
              Z-SUS EAX39648501
              thanks
              Greg
              • greglogan
                • Jul 2020
                • 18
                • United Kingdom
                In order to short out EXT_AUTO_GEN, should I solder in some headers or just bridge with solder and a piece of wire?
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  Highlighted are resistors for measuring VSCN (47kOHMs top) and -VY (100kOHMs top) and some others that fail when IGBTs short, they should not measure open or more than they're rated for.
                  VZB you measure from that resistor + to chassi ground.
                  I always solder a flexible small wire between the AUTO_GEN pads shaped like a U, to ensure there's no problem with poor contact.
                  Should also add, I've had one of these TVs with a defective top buffer, none of the output pads were shorted, but some SMD capacitors in parallel with the ICs were measuring 40 OHMs, and the Y-SUS VS fuse was open, nothing else damaged, replaced the fuse but the TV actually worked with half the lower screen, so a bit different than your fault.
                  • greglogan
                    • Jul 2020
                    • 18
                    • United Kingdom
                    Hi
                    thanks for the info. The z-sus board looks fine, however y-sus board appears unhappy. There is less than 0.5V showing on both VSC and VY. So, you're certainly getting me in the right direction it would appear. Some of the resistors are showing different values than their banding but I'm guessing that is because they are still in circuit? None are showing open or dead short.
                    Further checks ongoing but I'm open to any suggestions
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      On the Y-SUS board there are 2.2, 1.0 and 10 OHMs resistors circled, some 2.2 are in parallel, so should be 1.1 or less. I forgot to circle one below VR502, a red vertical one
                      If the resistors are good or bad, and the VS fuse on Y-SUS is good, you need to remove the board from the TV and check every IGBT and MOSFET in the heatsinks. Anything below 300 OHMs between C-E/S-D is a bad sign.
                      • greglogan
                        • Jul 2020
                        • 18
                        • United Kingdom
                        apologies for the massive edit. I checked both VR502 and R513 with my LCR tester. Approx 1.34 ohm which I suspect is within range.
                        Or am I going nuts?? Should these be 10.4K? Any help greatly appreciated!
                        many thanks
                        Greg.
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          I couldn't see the exact value because the on the photo they're vertical, the reading seems normal, they have 5 bands which confuse which way they're supposed to be read.
                          • greglogan
                            • Jul 2020
                            • 18
                            • United Kingdom
                            I think they're Brown / Black / Gold / Red
                            or possibly...Black / Red / Gold / Black but that doesnt seem to work either
                            The fact they're both reading roughly the same on the LCR tester makes me think they're ok
                            • greglogan
                              • Jul 2020
                              • 18
                              • United Kingdom
                              Looks like I'm gonna have to retire this one. It appears to be beyond my diagnostic skills
                              Thanks for all the help guys!
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • Cooperr
                                Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                by Cooperr
                                I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                10-21-2025, 01:11 PM
                              • stecos
                                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                by stecos
                                Hi everyone!
                                I happened several times, in the search for help from the web, to consult this very interesting forum.
                                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                Having said that I come to the gist of my post on the forum as the title suggests.
                                For my passion for technology I'm now collecting several...
                                11-28-2022, 11:39 AM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
