Samsung UE46D6750 double image problem
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    I have a Samsung UE46D6750 Smart TV.
    The image on the screen is doubled (only way I can think to describe it lol) please see attached pictures.
    The lady who owned it said it was working fine until she lifted it down off the wall. I dont know if this is just coincidence, or may be a factor.
    I have cleaned and re connected all cables from main board to Tcon, and ribbon connections from Tcon to drivers.
    Any help greatly appreciated, thanks in advance
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UE46D6750 double image problem
    Power up the tv with only one side connected at a time between the tcon and panel. If one side is good, you can try the tape cutoff method on the bad side.
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Here are some pics of what it is like with only 1 side connected at a time.
      Im not familiar with the 'tape cut off method'
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Hi the method I think is that you isolate a small part of the contact that goes from main to Tcon you lose on exp two or three contacts from right to left or the opposite and every time you see what happens on the screen. There is a video on youtube about this error or solution just type: https: //youtu.be/NgIP9gitrlo
        • Bloopeta
          • Jun 2018
          • 526
          • United Kingdom
          Have you tried this method yourself? Do you have more information such as how many pins should the tape be covering etc?
          Also, is this fault down to the Tcon? Or the Mainboard?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Hi Bloopeta
            There is a lot of information on this site on the cut-off method if you do a search using the Search box above.
            The fault is extremely similar to a tab issue so perhaps too much pressure was exerted on the one side when taking it down off the wall.
            You could check if any of the small IC mounted on the tab ribbons are running hotter than the others.
            If you put some slight pressure along the side where the defect is does it alter the image?
            • nomoresonys
              • 12306
              • U.S.
              Tape: https://www.youtube.com/watch?v=NgIP9gitrlo
              • stejones
                • Apr 2012
                • 55
                • United Kingdom
                Hi guys need a little help i have this model tv and the other day the tv just turned off and kelped clicking my initial thoughts was its down to the psu so i bought 1 and still did the same so i unplugged the lead from the power board to the main av and the screen lit up now my question is could this be a issue with the lead or the main av board im unsure many thanks
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Since this is completely different issue, you should start new thread.
                  • THXFX
                    samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                    by THXFX
                    Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                    I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                    When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                    What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                    I check capacitors and diodes and didn't find any short IN MAINBOARD.
                    Measured all power supply...
                    03-20-2024, 03:21 AM
                  • jason123
                    Hisense 65R6E3 double-image / horizontal strips - TCON?
                    by jason123
                    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                    07-19-2025, 08:07 AM
                    09-07-2024, 05:50 AM
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
                  • howardc64
                    TCL 49S405 double image
                    by howardc64
                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                    06-23-2025, 03:20 PM
