Insignia LED TV - Won't turn on
  • BradW
    • Sep 2020
    • 13
    I am trying to repair a single-board LED Insignia TV.
    Model NS-39D220NA16
    When plugged-in, the red standby LED lights for about 1-second and then goes out. It will not come back on until unit is unplugged and then plugged back in.
    Rinse and repeat.
    I have no schematics and the board is not marked very well.
    On the underside of the board, I did find a test point for 1.15v Standby and that reads 1.17v.
    There is also a 5v Standby and that does read 5v.
    I have tested all diodes and they appear Ok as do the transistors that I could identify and check. (Tested using ohm readings and Diode mode)
    All caps look very good but I have not unsoldered and checked although I plan on doing that.
    Any suggestions on what to check next?
  • neilc6
    • Nov 2015
    • 1550
    Re: Insignia LED TV - Won't turn on
    You need to determine if the TV is turning on and off with no backlight or not turning on at all. If the TV turns on with no backlight, you probably have bad backlights. If the TV doesn't turn on at all, you possibly have a bad eeprom.
    • BradW
      • Sep 2020
      • 13
      Stndby LED turns off by itself in a second or less.
      Nothing happens when I press power button. I've used bright flashlight to check for image but there is nothing so I don't believe I have a picture.
      Is it possible to get a new eeprom or should I cut my losses and just get a replacement board?
      I think I've identified the eeprom as shown in attached pic.
      The chip is labeled 25Q32BSIG and appears to be a reprogrammable chip.
      • neilc6
        • Nov 2015
        • 1550
        With the TV unplugged, spray the eeprom with an upside down can of duster to cool it. Plug in the TV and see if it turns on.
        • BradW
          • Sep 2020
          • 13
          Spraying (freezing) the eprom didn't work but I did notice that the Stndby LED went ON, OFF and then back ON for a few seconds. It went off again and TV would not turn on.
          Since something different happened, I decided to put board in the freezer for a few minutes.
          This time, the SB LED stayed on and the TV powered up Ok and I was able to navigate the menus, etc.
          I let it run for 10-min. and then powered off.
          SB LED went out and nothing would work after that.
          Froze board again (a little longer this time) but no luck.
          So the TV functionally works but it just refuses to power on consistently.
          The end user did say that they could get the TV working sometimes if they plugged in and out many times so I think I just got lucky on that one time.
          I also let it on for a few minutes and felt many components and nothing seemed warm or hot to touch.
          Any other thoughts before I just replace the board?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4546
            • Italy - Milan
            Do oyu have an eprom programmer and better also a chip clip? If yes put it in the freezer then read the flash in a hurry then rewrite it on, retry, if this doesn't work try the reflow on the cpu, or pressing on it with a shim under the board in the menatime you turn on the set.
            • neilc6
              • Nov 2015
              • 1550
              You can reprogram the eeprom with a cheap ch341 usb programmer.
              The processor doesnt have a heatsink and is not bga so no point in reflowing it.
              • BradW
                • Sep 2020
                • 13
                Thanks for tips.
                I have ordered a replacement eeprom for my TV model from ShopJimmy.com.
                • BradW
                  • Sep 2020
                  • 13
                  The replacement eeprom fixed the TV!
                  Thanks very much for suggesting that.
                  • nomoresonys
                    • 12323
                    • U.S.
                    Nice work, another one saved.
                    • PNI E.
                      Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                      by PNI E.
                      Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                      03-17-2025, 04:23 AM
                    • madsox
                      Harman Kardon AVR 171S - standby led lights up, does not turn on
                      by madsox
                      Greetings!
                      Thank you in advance for your understanding, I am writing to you through a translator.
                      A Harman Kardon AVR171S amplifier was given.
                      The history of the machine is as follows:
                      It was faulty when I bought it, I want to fix it.
                      I replaced the HDMI switch and one of the DAC ICs in it.
                      After that it worked without a problem.
                      I watched a movie using the amplifier, and at the end the amplifier got really hot.
                      The cooling was faulty, I will fix this later.
                      I switched it to standby mode, waited for...
                      09-24-2022, 10:46 AM
                    • pajdek
                      Lenovo Y700-17ISK turn on and off
                      by pajdek
                      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                      09-20-2023, 02:49 AM
                    • tbsmith
                      Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                      by tbsmith
                      There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                      08-11-2025, 06:15 PM
                    • Adenitz
                      Troubleshooting Vestel TV, has standby, but cannot turn ON
                      by Adenitz
                      I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                      Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                      Both boards are shown in the attached photos.
                      What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                      12-27-2023, 03:43 AM
