desk lamp stopped working... stars?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    How many bcn readers does it take to screw in a light bulb into my LED desk lamp?
    Answer: None. This is a nonreplacable-LED desklamp.
    So this lamp has one of those aluminum stars and an LED on it. It appears to be some sort of BGA or something with pins underneath. Anyway the PSU is 500mA 3.6V-8V meaning this probably was either meant to massively overdrive 1W LEDs or slightly over drive 3W LEDs...
    So it seems that typical 1W LEDs on stars are indeed 3.6V @ 300mA to get 1W which would be overdriven at 500mA, and 3W LEDs appear to be 3.6V@700mA which is a bit under spec, but would be less than 2W with the PSU I have.
    The original star that I have is a 7.2V 2S configuration at 500mA which is 3.6W...
    Question is where can I get a replacement... with heatsink, do I try to remove+replace the old LED from the heatsink, or do I bother replacing it and trashing the whole lamp? Appears the LED package has a die bond failure as I can press on the package and sometimes can get it to light again.
    • Jul 2011
    • 6070
    Re: desk lamp stopped working... stars?
    Post a picture of the item in question
      • 31250
      not just a picture, show us the optics if any, and tell us the diameter.
      you may be better off with a cob panel.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Hmm.. it's about 18mm in diameter, so yeah dunno... A lot can be told by a good closeup, not a BGA after all.
        I have a few 1W SMT lensed devices I could solder on to the free pads but not sure how to attach the heatsink of the LED to the star.
          It looks like typical 1W TV LED backlights.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            Well this thing should be "4W" (wall power) and it should be around 7.2V or 2 LEDs in series.
            Some more accurate measurements:
            LED encapsulation is 5mm x 5mm so 5050(metric) SMD package?
            Star is 20mm diameter.
            Now where I could get these things without buying a boatload of them...
              • 31250
              maybe fasttech
              https://www.fasttech.com/
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                hmm...difficult to find 2S ... most are single diodes...
                  • 31250
                  does the led get power?
                  it looks like the star may be shorted by the wrong screws
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Yep it gets power all the time, just doesn't light.
                      • 31250
                      so is the psu cased/marked ?
                      some are constant current - others are constant voltage.
                      be usefull for selecting a replacement.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        PSU is CC @500mA.
                        If it comes down to swapping the PSU along with the LED, it really means throw out the whole lamp... Need LED only replacement if possible.
                          • 31250
                          so any 500ma led then.
                          isnt that about 2w??
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            At 7.2V which is the 2S original diode, it would be just under 4W. It would be just under 2W if I had to go with a single diode.
                              So it is CC 500mA power supply , but what does it say as far as the Voltage is concern on the power supply?
                              CC 500mA power supply will force constant 500mA through the load, so if you connect one LED or two LEDs (in series), the current will be maintained at 500mA.
                              The Star board is 20mm Dia.
                              For example:
                              https://www.ebay.com/itm/1W-3W-5W-Wh.../324179513914?
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                Well, the PSU voltage range is 3.6V to 8V so it can drive a single (white) LED at 1.8W or two (white) LEDs in series at 3.6W, and can go up to 4W if the LEDs will go up to 8V.
                                Which means I could theoretically stick in three red LEDs in series and it'd still work though at 3.1W, unfortunately I don't need to stop...
                                (Which the original issue is ...where do I get an LED that won't fry when I put it in... I have a few 1W 3.6V LEDs but they'd be driven at 0.5A which will force the LED to dissipate near double its rated power. Perhaps I need to mod the PSU to run at 300mA?)
                                  • 31250
                                  your looking for a round cob panel not an led.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8703
                                    I can desolder the LED from the plate too... well, with a back heater of course.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      My current thinking is desolder the dead SMT LED and solder two 1W (1S, 300mA) LEDs in parallel though this is probably still going to end up with the same result as if I only put in one: one of the two LEDs will eat most of the 500mA and fry.
                                      The other question is maybe the LEDs will take 500mA just fine if I can cool them... if I can cool them...
                                        Show us the pictures of the CC power supply, may be all you have to do is to change the value of the current sensing resistor that is used for setting the CC.
                                        • aneng
                                          What kind of desk lamp / magnifier do you use ?
                                          by aneng
                                          Hi.
                                          I need to get a bright desk lamp for working on PCBs and I'm wondering what is considered the best type to get for this kind of work ?
                                          I see there are a lot of magnifier type lamps with ring lighting, but the magnification is usually only 5x, which I don't think is going to be enough for SMD work, though it might be OK for larger components / general use.
                                          There are also the long LED strip kind.... which seem like they might be good.
                                          I think that either way, I want to go with a swing-arm type ('anglepoise' type) rather than a gooseneck...
                                          03-25-2021, 04:47 AM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
                                        • mikey5791
                                          Help on Samsung Syncmaster T220 dead ccfl lamp
                                          by mikey5791
                                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                          10-18-2020, 03:17 AM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
