using a 5v spi programmer for 3v bios chip question.
  • dglt
    • Oct 2020
    • 4
    this is a little after the fact but i was wondering if it's something i should be concerned about using one of those cheap $10-$15 CH341a SOIC8 spi programmers found on amazon to flash a 3.3v bios chip?
    the programmer is advertised as 3.3v but actually show as 5v on a meter. i only ask because recently i used one to pull my legion 5i laptop bios > mod > flash back to rom, the first time i did this worked no problem but when i went to do it again a day later after some changes the laptop wouldnt post (just power light on 5-10 seconds and then off 5-10 seconds and on an infinite loop until battery is pulled).
    so i tried again but noticed the SPI programmer also didnt work (on any chip), this has me thinking both the programmer and the laptop stopped working at the same time. i ordered a new functioning programmer+clip but even my original bios backup will not boot, same power loop issue. the flash finishes and verifies
    • 31131
    Re: using a 5v spi programmer for 3v bios chip question.
    most flash chips have 5v tolerant inputs, but the output is only 3v, so while your unlikely to damage the chip you may have a chance of errors.
    be carefull btw, some newer laptops are now using 1.8v flash chips!!
      • 21404
      Search through the forum you`ll find lots of info about the CH341A . There is a 5V to 3.3V mod you can do ,and theres alternative software such as AsProgrammer,NeoProgrammer,Colibri and flashrom .
        • 31131
        10-15$ on Amazon?? fuck Amazon.
        you can get them for 2-3$ on ebay ./ aliexpress
          • 21404
          It must be the black and gold-plated version at that price. Amazon do have a good return policy.
          • dglt
            • Oct 2020
            • 4
            thanks everyone for the replies, yeah they both are the black/gold iirc. i have the 1.8v adapter that came with the second one, i was just trying to understand if its possible that i burnt something out on that last flash before it broke. on the backside of the board i found 1 mosfet that looked like it had a hazy film over it and another chip im told is what handles power delivery but i couldnt find online so please excuse the lack of a better term(i'll attach a photo showing both)
            that "power delivery" chip instantly gets burning hot as soon as battery, ac, or both are plugged in and before even trying to turn it on.
            am i right to assume there is a short somewhere causing this?
            https://imgur.com/a/NKvkuNz
            • Matias80
              • Nov 2020
              • 7
              • ARGETINA
              It can usually be adapted by making a resistive divider. Although a zanner resistance divider would be better to be safer.
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
                Common SPI bios chip programming Questions and Answers
                by SMDFlea
                Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                A: If you can`t read from it how do you expect to write to it ?.
                Q: Why is my bios chip unreadable ?.
                A: The programmer is faulty or has a worn or broken zif socket.
                The USB cable is frayed,connector pins worn or some other physical damage.
                Not enough amperage or voltage to power the programmer properly.
                Bad...
                09-02-2021, 04:40 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • inck243
                Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                by inck243
                Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                The BIOS...
                07-25-2024, 09:17 AM
              • Azurain
                Elitebook 840 G5 Bios Chip Soldering Question
                by Azurain
                Hi everyone,
                I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                04-14-2023, 06:58 PM
