A motor controller is a power supply, right?
  • cjard
    • May 2014
    • 14
    • US
    Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning the motor sees "negative positive" on 1 and 2
    So, that part seemed ok.. The relays are fine, but there was no negative to the motors even tho the positive was OK
    Turned out there were a parallel pair of MOSFETs on the negative side of things for each motor and all the MOSFETs were blown/gave crazy readings. I swapped them out like for like and one channel now works fine, the other channel has an issue:
    It works fine if I use my multimeter to supply a bit of voltage to the MOSFET gates, but the board itself doesn't supply it. Having caught a comment on the web that "blown MOSFETs can cause the driver circuits to be damaged too" I'm checking the circuit that drives them. Because the board is more or less symmetrical in terms of components I traced back from the gates on each side to see where voltage differed, comparing working vs broken, and where it was the same. I'm no electronics genius, but it's proving to be an interesting learn
    So I've photographed the two relevant halves of the board. You can see one of the FETs in the top right (NMOS6) and that's the broken side - so the thin track that leads under each cap is the gate line:
    On the left side the gates are at 12v (red overlay) when the board is powered, on the right they're at 0v (blue overlay). Working vertically down the picture there are a pair of transistors - one's a J3Y and the other is really hard to ID - seems to have 3K written on it on the left, seems to have a hole in it on the right. I believe (if I'm understanding the datasheet schematic correctly) that this means the gates are connected to the emitters and on the working side the base pins are at 0v (blue), on the broken side the base pins are at 0.8v (orange). Everything else seems consistent each side of the board, though the layout differs the circuit seems to be the same. I stopped tracing back when I reached the same 5v (purple) or 12v (everythere else) so the majot difference seems to be this track that links all 3 transistors in some way - 0.8v on the broken side and 0v on the working
    I drew this:
    which I think is right, though the circuit simulator doesn't seem to indicate any 12v should reach the gates so it's probably incomplete, or I've got the BCEs the wrong way round, or something else to do with the transistors...
    Any assist on that I should be doing to repair this?
    Replacing the exploded transistor is first up, but can I raid any transistors out of a computer PSU i have kicking round? Or should I just be ordering exact replacements.. and what is the exact replacement for the one with the hole in?
    Will the J3Ys need replacing too or might the voltages I see be explained by damage on only the one with the hole in?
    Am I right in thinking these transistors are J3Y (easy to see) and a 3K (?) (It's a BC858B?) The transistor with the hole in has "3(hole)2" and the 2 is rotated 90 degrees. The "same" one on the working side of the board has "3KDO" written on it, except the DO is 90 degrees rotated and looks more like |)() because the letters have a break in the font at the top and bottom..
    It's a bit nasty too, but if I don't get any joy from fixing this side, sould severing the gates line and bridging it to the gate line on other side of the board also work?
    Thanks in advance for any pointers!
    Re: A motor controller is a power supply, right?
    You need to show good clear straight shots of the whole top and bottom side of the board, and also how all the boards and other parts are connected to the boards.
    • cjard
      • May 2014
      • 14
      • US
      As requested:
      Note these images have the MOSFETs removed (except one known good as a test). On the base of the board most of what you see is either negative or positive. This board connects to nothing else except 12v DC In on the middle bolt pair (and 12v DC out on the outer bolt pairs depending on motor direction). The red fly leads go to some devices that are some kind of thermal cutout I believe- glued to the lids of the lower two relays (which are constant energized when power applied). The bit of paper wedged in the relay can be ignored too
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        Is the voltages the way you measured on the board? Seems the circuit input is active low and when power needs to be supplied that input +5V needs to go to 0V.
        As colored up and voltaged, with that first npn transistor connected to +5V/high, the mosfet gates should be off and the mosfets themselves should be off. This would imply the upper left NPN transistor in the left side of the picture is shorted and that needs to be replaced.
        • cjard
          • May 2014
          • 14
          • US
          hi eccerr0r
          Yep, the coloring in reflects the voltages I measured on-board when the board is powered up
          It's the right side of the colored-in pic that is faulty, the left side (with 0v between the transistors) works ok/ supplies 12v to the gates of the IRF3205s when the board is powered up..
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            So your "simulation" schematic is wrong because as drawn, the gate drive is supposed to be 0V and the mosfets off. You'll need to retrace again.
            In any case that transistor seems to have failed if indeed is an npn transistor, having the base at 0V, emitter and collector at +12V, something is very wrong with circuit biasing and that device is now shorted due to reverse breakdown.
            • cjard
              • May 2014
              • 14
              • US
              Not quite sure I fully understood what was said there, but here's a bit more info (that schematic is what I see when I don't ask the board to do anything i.e. its what I see with it powered up but not activating any motors):
              These FETs (IRF3205 NPN are present on either side of the board and they seem to be used to turn the negative on and off to the motor - I say this because there is a large bolt to which the user should connect his battery, labelled N, and this bolt is clamped to a big rail that runs round the board. All the FET source pins connect to this rail, the drains connect to a pair of relays (that also receive a positive 12v from elsewhere) that are switched alternately to make the motor go backwards or forwards accordingly.
              On the side of the board that works, the FET gates receive 12v as soon as the board is powered on. On the side of the board that doesn't work, the gate line is at 0v.
              The relays all energize as they should to carry out the switching but the motor only turns on the side where the FET gates are at 12v. I've noticed, however, if I use my multimeter in diode mode to supply some volts to the gate line on the broken side of the board (with the neg probe on the source rail), then all the motor channels work as expected; seemingly the multimeter has activated these FETs in place of whatever is supposed to do it on the board proper. If I short the gate and drain then the motor becomes inoperative again
              I've checked and double checked different datasheets for these transistors, and they all seem to say that (looking top down with the one leg on the left and two legs on the right) the left leg is collector, top emitter and bottom base, and I've looked at that schematic about 20 times checking it - i'm sure it's right unless the components I have have a different BCE arrangement.. The voltages I've put in the schematic are those as measured with the board powered and no remote buttons pushed.
              When I push a remote button and activate the relays, then for either side (working or broken), the 5v falls gradually to 0v over about 5 seconds.
              On the working side the 0v between the transistors gradually rises to 3.6v.
              On the broken side, the 0.8v between transistors gradually falls to about 0.5v
              On the working side the gate line drops from 12v to 11.5v but I figured this was due to a weedy power supply running the relay, I'm not sure. I've only got a crappy grade multimeter..
              From previous queries/asking around it was suspected the MOSFETs might be used as a soft start system, but I don't know how to verify it
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                In a properly working circuit the node that's common to all three bjt transistors (collector of first, bases of other two) should drop to near 0V when the "+5V" input to the first transistor and resistor is at +5V.
                The common to all three bjt transistors should reach +12V when that "+5V" input goes to 0V.
                The output of the two "final" bjt transistors should mirror what the "common to all three bjt transistors" node. So the side where it says "ningbo bainian" matches what I think is what should be proper operation of the transistors. The other side, if the circuit is measured properly, appears to have a faulty J3Y transistor. However this appears to be contrary to what you say is true so
                - your schematic is wrong (also: Where is that diode connected?)
                - your voltage measurements are wrong
                - the voltages measured in the first post are not steady state and in the 'on' condition and measured at the wrong time.
                • cjard
                  • May 2014
                  • 14
                  • US
                  I don't know where the diode connection goes - it's "the point beyond which the voltages are the same and I stopped measuring"
                  The schematic is "wrong" in the sense that the colors don't match what I measure - I didn't draw the colors; falstad's circuit simulator does that for me and I can't make the sim match the voltages I measure (dont know how). If I toggle the 5v between 0 and 5v I can see that the output of the NPN-PNP pair whose emitters are linked switches between 0v and 12v when the 5v goes to 0v (respectively)
                  Ignoring the schematic voltages for a moment, and just looking at the components, I'm sure that the schema I've drawn reflects the components placed on the board, but if you think i've made an error in terms of connecting the components, let me know..
                  The voltages measured and stated in the first post are "board powered on, no remote buttons pushed" - the voltages are steady, but not representative of what happens when the remote button is pushed.
                  I can't explain what I measure on the "non NINGBO" side of the board; I know you're saying it's wrong, but that's the side that "works" in that it turns the motor.. I'll make a video of the volt checks soon. I'm not sure if you're saying I'm wrong/have measured incorrectly/am blind, or that the circuit is not functioning correctly per the schematic design? Perhaps if these fets are supposed to provide a soft start I should see some pulsing (not sure my meter is fast enough), or at least that the gate line should have some sort of switching behavior and shouldnt immediately go to 12v when the board is powered on?
                  The NINGBO side of the board had a "3K" (I think it means BC858) PNP transistor with a hole blown in the top - i've taken it off the board and get a reading of 240 between base and collector on my meter (leads any way round), nothing for anything else.. I understand that for a PNP I should have had a reading of about 700 emitter(pos lead) to base(neg lead) and same ish for moving pos lead to collector, on the multimeter I have.. So I think it's a fair bet that transistor is a goner
                  Also for the ningbo side, that gate line is at 0v and stays that way.. So perhaps both sides of the board are faulty but for different reasons; the non-NINGBO side activates the MOSFETs permanently when it should switch them and the NINGBO side never activates them
                  I've found an A733 PNP transistor in an old power supply; is it a compatbile replacement for the BC858 with the hole in the top? Specs seem broadly similar but I've no idea what I'm reading..
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    A733 is TO92 but for your specific case it should work fine.
                    Sorry I can't help anymore, the data you give doesn't correlate to each other, too many either board track extract errors or measurement errors in the data you collected.
                    • cjard
                      • May 2014
                      • 14
                      • US
                      Yes, it's a different package but I can rearrange the legs so it perches in the right place
                      So you'd say there's a possibility that some of the J3Y are damaged too? This could explain some things; I've been following "how to test your transistor" guides and I just couldn't get them to match up to how the components behaved. I thought it was just because I was testing them in-circuit (which I understand can't always work out because other components present on the circuit will confuse the readings) but I couldn't get the readings to match from one side of the board to the other either
                      I think it's probably better to just pull all the transistors out of both sides and bench test them all..
                      Another couple of questions for you if you will: I've also managed to raid a PC power supply for a few SC8050 transistors. Will these work adequately equivalently to any J3Y that I find defective?
                      Is there any way to tell from the readings I have given which J3Y is damaged/which I should pull and test first ( on the non-NINGBO side; the size that puts its mosfet gate line straight to 12v?)
                      • cjard
                        • May 2014
                        • 14
                        • US
                        I was able to resolve this, hopefully; turned out every transistor in the schematic above, was toasted bar one J3Y.. Schematic was right, but the volts I had measured were completely out of whack because of the number of damaged components
                        Not having enough time to wait for the exact replacements to arrive I raided 3 PC power supplies and was able to cobble together a pair of SC8050 and an A733 for one side, and a pair of 2222As and an A1015 for the other; reshaping the legs suitably so they perch where the SMDs used to be
                        Now have MOSFET gate lines that steadily rise in voltage the longer the button is held down and same for the actual motor output lines. The tech department for the device were able to confirm that the MOSFETS implement a soft start
                        Thanks to eccerr0r for the pointers on what to check and replace!
                        • juergenb
                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                          by juergenb
                          i am asking for some Help.
                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                          So i got a few of these from Banggood.
                          I swapped the motor and now i have a new fault condition.
                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                          If you press longer it will light blue and just mixup the milk.
                          With the new Motor it just starts...
                          03-23-2021, 11:24 AM
                        • sbt123
                          charnwood w821 mini wood lathe motor problem
                          by sbt123
                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                          10-27-2024, 03:43 AM
                        • d00m178
                          Philips toothbrush 4100 (HX369BK) - motor getting hot
                          by d00m178
                          trying to fix Philips toothbrush 4100 (HX369BK)
                          The battery started draining quickly.
                          After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
                          The motor is connected to contacts M1 and M2.
                          When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
                          But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
                          The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
                          (To...
                          11-12-2025, 03:11 PM
                        • edugimeno
                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                          by edugimeno
                          Hi everyone!
                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                          I respected the polarity, positive to cathode of protecting diode
                          So provided all...
                          04-18-2024, 01:15 PM
                        • madan1
                          DALI SUB E-12F class D, fluctuating power rail
                          by madan1
                          Good day everyone.
                          I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                          The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                          The normal value of the positive and negative power rails is +/- 43V.
                          The positive rail stays...
                          10-15-2025, 10:33 AM
