No backlight on Samsung LN46C600 - Fixed!
  • cabele
    • Oct 2020
    • 2
    The screen was completely dark on a Samsung LN46C600. The power light worked normally, it made the normal sound when turned on, but just a black screen. With a flashlight you could see that the LCD was still showing an image.
    Since ALL of the LED backlights were off it seemed pretty obvious that it had to be a power supply problem, rather than a bad LED (which might cause one LED string to go out).
    It's pretty easy to take the back off the TV, removed the power supply board, and looked for failures. I didn't see it at first, but eventually noticed that CI818 was bulging. I found the power board schematic and some other documentation online (http://www.toms-service-manuals.com/), and it showed CI818 as 0.47uF at 450V. Digikey has the Panasonic ECW-FA2J474J (DK #ECW-FA2J474J) for just $0.81, which is 0.47uF at 630V. I replaced the bad part and the backlight worked again!
  • neilc6
    • Nov 2015
    • 1550
    Re: No backlight on Samsung LN46C600 - Fixed!
    If you search your power supply part number BN44-00341B you will find lots of threads on this fix.
      +1
      BTW, this TV does not use LEDs for backlights.
      • nomoresonys
        • 12216
        • U.S.
        Yep, that little bugger fails quite often.
          09-07-2024, 05:50 AM
        • howardc64
          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
          by howardc64
          TV was fixed just after removing Samsung's rear snap cover.
          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
          Maybe PSU->backlight connector didn't have a good contact?...
          07-23-2025, 12:34 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
