LG 47LS4500 picture issue
  • Rmasters3
    • Mar 2010
    • 126
    After swapping the power supply, this is how the picture looks. Vertical band lighter top to bottom of display
    PS had a number of issues bulged electrolytics, 15A fuse blown, and one ceramic cap bulged. Might have been other problems too, but swapping the PS was simplest fix, and I have no information if the set had this vertical bar before PS died.
    Suggestions?
  • nomoresonys
    • 12305
    • U.S.
    Re: LG 47LS4500 picture issue
    Grab the bezel with both hands and give it a squeeze, right there where the line is, try it on top and bottom, just squeeze the bezel, don't touch the screen, see if the line changes any.
    • Rmasters3
      • Mar 2010
      • 126
      Do you mean squeeze bezel at top and bottom of lighter area?
      • Rmasters3
        • Mar 2010
        • 126
        Tried squeezing bezel at top and bottom. No change--back panel is still removed from replacing PS.
        I do get three blinks of the On/Off red light when the set turn on.
        • nomoresonys
          • 12305
          • U.S.
          Feed it a signal see how it displays, maybe try a dvd player.
          • neilc6
            • Nov 2015
            • 1550
            That vertical band band corresponds to one of the TAB bond/flex cables (second one in from the edge). You can try putting some pressure on it but likely not repairable.
            • nomoresonys
              • 12305
              • U.S.
              If putting pressure works, it may be a candidate for the shimming technique.
              • Rmasters3
                • Mar 2010
                • 126
                Any particular method for this pressure treatment?
                • nomoresonys
                  • 12305
                  • U.S.
                  One there, might be able to find some with more detail but the gist is there: https://www.youtube.com/watch?v=8l5ORKjQF5U
                  • Rmasters3
                    • Mar 2010
                    • 126
                    Tried everything suggested and no-go. It's headed to the curb. Thanks regardless
