55LA6205UA LG with unusual issue
  • engyshe
    • Jan 2015
    • 14
    TV works for 20 minutes. Then the screen goes black but the sound stays on. It comes back normal after 90 minutes (not seconds). If I turn off the TV and then back on again before about 90mins, it will flash the LG logo briefly then will be black again. Unplugging the TV and plugging it back in makes no difference.
    I do not understand where this timeout of 90 minutes could possibly be coming from. Any ideas. Thank you
  • neilc6
    • Nov 2015
    • 1550
    Re: 55LA6205UA LG with unusual issue
    https://techhometravel.com/lg-ln-ser...ed-backlights/
    • engyshe
      • Jan 2015
      • 14
      Thank you
      • jjanssen7
        • Nov 2012
        • 252
        I believe the center connectors on on the LED strips go bad on that model sometimes. Something worth checking when all the LEDS work and then BL shuts off after 60 minutes or so.
          Try turning down backlights level (not Brightness) to as low as possible to see if it will stay on longer than 90 minutes.
          • engyshe
            • Jan 2015
            • 14
            Thank you all
            • engyshe
              • Jan 2015
              • 14
              Thank you all. Now that I think about the suggestion of center connections going bad, it totally makes sense. That is the only thing that can explain 90 minutes off time after 20 minutes on time with LEDS being actually ok. With active heat it takes 20 minutes to stretch the led strip and 90 minutes to contract back to the original length and make contact again. This was cool. Thank you
              • engyshe
                • Jan 2015
                • 14
                Here is a crazy idea. Would placing a 3/4" wide Kapton tape over the center connection be counter productive in any way. I do not see how (the tape is designed for high temperatures, it is not electrically conductive, it is ESD safe, holds well). If this is truly a failure mode, it means that LG failed in the design between the mounting of the LEDs and the strip temperature expansion, and help to re-enforce the joints would be a good idea.
                • jjanssen7
                  • Nov 2012
                  • 252
                  it only takes the slightest "tap" to reconnect the leds, so that suggests the problem may be with the electrical contacts themselves as well as thermal expansion. I think the only fix is to solder jumpers across the connections.
                  • engyshe
                    • Jan 2015
                    • 14
                    Again thank you for the help. Cheers
                    • coasterghost
                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                      by coasterghost
                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                      System Hardware:
                      Processor: AMD Ryzen 7 PRO 5850U
                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                      09-08-2025, 10:46 PM
                    • Leebo249
                      SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
                      by Leebo249
                      Hey,
                      A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
                      Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
                      Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
                      09-07-2025, 07:23 AM
                    • Titus6
                      LG OLE65C1 Stand-By issue
                      by Titus6
                      I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                      However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                      I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                      01-31-2025, 04:01 PM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
