820-3437-B no light and fan spinning fast
  • brumbrum
    • Sep 2016
    • 24
    • Italy
    Good morning everyone,
    I Have a MacBook air logic board that first came in for no power.
    I removed ssd and wireless card.
    With charger I got only orange light, and if I press power button the light became green just for 2 seconds (the system feels when I press power button).
    The issue it's: no boot, no power on, I have v core, 1.7v, but as I plug the charger, green light 2 seconds and orange light with fan stuck spinning.
    Nothing except cpu on board is hot, no corrosion, I haven't found any short, and I checked that voltage rails checked and are ok:
     PM_SLP_S5_L – 3.3v
     PPBUS_G3H
     PPBUS_S5_HS_COMPUTING_ISNS
     PPBUS_S5_HS_OTHER_ISNS PP5V_S5
     PP5V_S4RS3
     PP5V_S0
     PP3V3_S5
     PP3V3_S4
     PP3V3_S3
     PP3V3_S0
     PP1V8_S3
     PP3V42_G3H
     PPVRTC_G3H
     PP5V_S5
     PP5V_S4RS3
     SMC_ADAPTER_EN
     PCH_SRTCRST_L
    Issues:
     PM_SLP_S4_L -> 0v
     PM_SLP_S3_L -> 0v
    Can someone help me to fix that crazy board? thank you
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-3437-B no light and fan spinning fast
    Keyboard is probably bad.
    If you have S3 and S0 rails present, PM_SLP_S4_L and PM_SLP_S3_L cannot be 0V.
    • brumbrum
      • Sep 2016
      • 24
      • Italy
      But I've disassembled the board, with only magasafe connected, and problem is still the same
      • piernov
        • Jan 2016
        • 4437
        • France
        With a good keyboard it shouldn't cause Magsafe light to turn green then orange again when pressing power button (could also be caused by touchpad but less likely).
        It's not clear what the problem is though. Your measurements don't really make sense and you haven't properly described the symptoms. You say no power but at the same time "fan stuck spinning" and CPU getting hot.
        So, with only the board: orange light on Magsafe? Fan spinning?
        With a USB drive plugged in, activity LED blinking?
        Chiming with speakers connected?
        Image and backlight with LCD connected?
        • brumbrum
          • Sep 2016
          • 24
          • Italy
          ok I'm sorry. I'm trying now to explain better now after Smc replacing.
          No power with battery connected, no sign of life. No chiming or any sound, no image and no backlight.
          If I plug magsafe, I get green led and fan spinning for 2 seconds, after that fan stop and led became orange. With orange led, fan keep spinning stuck at the same speed, and only cpu is hot, and of course no chiming or any sound, no image and no backlight.
          With a USB drive plugged in, activity LED not blinking.
          The behaviour of the board is the same, with or without keyboard and touchpad connected.
          • piernov
            • Jan 2016
            • 4437
            • France
            So with logic board, DC-in board and fan: fan spins, stops and spins again?
            This board should have fan spin, stop, spin, stop and then spin again instead.
            So you replaced the SMC? What led you to replacing the SMC? Did you take the SMC from same model donor board?
            • brumbrum
              • Sep 2016
              • 24
              • Italy
              I already replaced the smc cause under microscope I noticed that there was a little "ball" (like blow up) on the chip, even if under the chip everything was ok.
              I didn't have a similar donar board to take it from, so I bought a new one with similar number:
              the new one:
              LM4FS1BH 5BBCIG 48A491W
              the old one:
              LM4FS1BH 5BBCIG 33A6GSW
              But the issue is the same.
              • piernov
                • Jan 2016
                • 4437
                • France
                SMC must come from same model donor board. It has a firmware that's specific to the board model.
                • brumbrum
                  • Sep 2016
                  • 24
                  • Italy
                  oh, thank for this info. so, it was my mistake, I didn't know it. Now should I buy another one already programmed for this model? or can I program it in any way?
                    Lithonia Lighting versus Light of America Compact Fluorescent product quality
                    by sam_sam_sam
                    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                    I also have back when Light of America had these light bulbs available for yard lights
                    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                    While the Lithonia lighting fixture has all most certain bulb failure
                    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                    I have only had this light fixture for not more than a year if it...
                    07-02-2023, 03:45 PM
                    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 03:40 AM
                    LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 09:10 PM
                    09-06-2024, 08:40 PM
                  • serious_electron
                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                    by serious_electron
                    Hello Everyone!
                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                    06-28-2025, 02:57 PM
