Help identify smd ceramic capacitor - Samsung UE55KU6775U
  • bohaboha
    • Nov 2012
    • 1080
    • sweden
    Hello can anyone help identify the value of those smd ceramic capacitor? C115 and C117 they look similair or tell me how to do to identify these smd capacitors
    thank you
    Last edited by SMDFlea; 10-29-2020, 12:00 PM. Reason: Added TV model number,moved thread to TV forum
  • redwire
    • Dec 2010
    • 3912
    Re: Help identify smd ceramic capacitor
    You can't tell their value by looking at them. They have no markings. The voltage also affects size.
    I would look at the schematic for the TV, but can't tell the make/model number.
      • 31316
      that's the panel itself.
      you need to remove one and meter it.
        Are they showing low resistance readings?
        • bohaboha
          • Nov 2012
          • 1080
          • sweden
          Hello all redwire the model and No: Samsung UE55KU6775U.
          budm at 200k they shows low increase higth to Ol but one of them get more hot when the tv is on
          • NuclearSpartan
            Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
            by NuclearSpartan
            Hi everyone,
            I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
            The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
            I don't see any other visible damage anywhere else on the board....
            11-14-2024, 02:32 PM
          • devsigner
            identify capacitor for MacBook Pro with rare logic board 820-02037-06
            by devsigner
            Hi
            While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
            resistance tests show a rising resistance value, indicating a capacitor.
            The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
            i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
            It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
            11-28-2025, 01:39 PM
            09-07-2024, 05:50 AM
          • chth96
            Is it possible to test small ceramic disc capacitor with analogue meter?
            by chth96
            I read EBOOK of Testing Electronic Component and found that
            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
            Is it really possible to test small ceramic disc capacitor with analogue...
            03-09-2024, 10:03 PM
            09-06-2024, 11:40 PM
