Hitachi Refrigerator R-Z270AUN7KV not cold.
  • SuperAman
    • Dec 2018
    • 121
    Hi, I have a Hitachi Refrigerator R-Z270AUN7KV. The fridge is on the bottom and the freezer is on the top. My problem is no matter what setting (1-9) the freezer is, the fridge is not getting cold but the freezer is always cold. I have tried all combination of settings for the fridge (Min, Mid, Max) but nothing. Fridge is always hot now. Before it would sometimes do this but now always fridge is hot. I believe the service center peeled some of the foil from the thermostat and that seemed to help a few years back. I replaced the thermostat recently and it worked off and on for a few weeks but now fridge is always hot and freezer cold for the past week.
    Re: Hitachi Refrigerator R-Z270AUN7KV not cold.
    The lower section get the cold air form the freezer section, so look for opening in the bottom section of the fridge to see if there is any obstruction, also look for a fan that circulate the cold air from freezer to the lower fridge section.
    Show us the pictures of the internal chambers of the fridge.
    https://www.gfyappliancerepair.com/b...-freezer-cold/
    • petehall347
      • Jan 2015
      • 4430
      • United Kingdom
      manual says ..Is the cold air vent blocked with food?
      • R_J
        • Jun 2012
        • 9579
        One thing to check is if the defrost timer is working, What can happen if it does not cycle, ice can build up around the freezer and block the air flow to cool the fridge. I have a fridge with a similar defrost timer and if the motor in it stops running, the fridge will not get cold. The timer should be located on the rear lower right, you can cycle it manually using a large flat blade screwdriver. If the fridge is indeed frozen up, you may need to turn the defrost timer until it clicks and the heat element comes on and do this a couple times, You should then see or here water running into the pan under the fridge.
        If this is the timer, you can turn the grey knob with a flat blade screwdriver clockwise. until it clicks, If the compressor is running at the time it will turn off.
        • SuperAman
          • Dec 2018
          • 121
          There was a buildup of ice on the coils. Cooled it down, melted it with boiling water. Now with the fridge and freezer set to the lowest settings, it has been working fine.
          • R_J
            • Jun 2012
            • 9579
            It will do it again, you just proved the defrost timer is likely not working. It needs to cycle the defrost element every few days to keep the ice from forming.
            You can operate the defrost cycle manually to melt the ice.
            • SuperAman
              • Dec 2018
              • 121
              Thank you. Is the defrost timer located in the freezer or fridge compartment? I don't recall seeing anything that resembled that in the freezer compartment.
              • R_J
                • Jun 2012
                • 9579
                The defrost timer is likely located on the lower part of the rear of the fridge, It will not be inside a compartment. Here is the location of mine, take a picture of the rear of your fridge if you can't locate it. When I checked the model of your fridge, the defrost timer for it is the one I posted in the picture, The original is likely black not white.
                • SuperAman
                  • Dec 2018
                  • 121
                  I don't see anything like that on my fridge. Here is a picture with the pan removed.
                  • SuperAman
                    • Dec 2018
                    • 121
                    • R_J
                      • Jun 2012
                      • 9579
                      I don't know where they put it on this model, but if it is a frost free refrigerator, it is there somewhere.
                      Here is the manual, with the schematic, trace the wiring to find the defrost timer, maybe it IS inside behind a panel somewhere?
                      The pictures are too small to make out what's behind that black box where the cord enters
                        • Jul 2011
                        • 6057
                        It might be with the temperature controller sensor behind the cover would be my guess
                        This timer might not have outside access to outside world would be my guess
                        But who knows where it could be
                        • R_J
                          • Jun 2012
                          • 9579
                          I suspect this is a similar fridge, It looks like it is item #38 behind the panel in the fridge compartment
                          • SuperAman
                            • Dec 2018
                            • 121
                            Thanks mate, it is a very similar model. Is it the #31 part in the diagram the defrost timer, I had suspected that was it? It did it again this week it worked fine for like a month or so.
                            • R_J
                              • Jun 2012
                              • 9579
                              NO that is the fan motor, The defront timer is #38
                              • SuperAman
                                • Dec 2018
                                • 121
                                Yes 38 I meant. So is there a way to fix it or adjust it? Or does it have to be replaced? It's a pain to access, much easier to access the freezer compartment.
                                • R_J
                                  • Jun 2012
                                  • 9579
                                  Maybe it can be fixed? I don't have it to be able to tell. There is no adjustment, it is a timer, I suspect the small internal motor is not turning for some reason.
                                  There should be a way to access the timer (post #6) so you can operate the switch manually by turning it with a flat screwdriver. maybe the access hole is under panel 42 or 36? If you can access it you can turn it to the defrost cycle, let it operate that way for about 10min, then advance it again to let the compressor operate.
                                  • SuperAman
                                    • Dec 2018
                                    • 121
                                    Thanks I found the little guy. The schematics were right, mine is a little larger though. I don't think I'm going to find a new one locally though. How many hours is this model, it is not clear? Can I replace with another one that is the same shape and maybe less hours of cooling and lower minutes of defrost? The heating element works because when I manually rotate counter clockwise the heating element starts and runs and some of the build up of ice is melted. Since there is so much buildup 1 manual defrost cycle wont cut it. The good thing is the timer is accessible, it os just above the fridge temp knob and there is a hole to rotate a screw driver.
                                    • R_J
                                      • Jun 2012
                                      • 9579
                                      The defrost timer only runs when the fridge/compressor is running. The defrost motor is connected across pins 1 & 3, check the resistance of the motor, if it is good then maybe you can get some type of cleaner to wash out the motor and the reduction gears inside it? If not just replace the timer, If you can find a used one it should be ok, you can order them off the internet, just be sure to get the right voltage (ac200~240)
                                      • ron350
                                        • Feb 2014
                                        • 296
                                        RJ cant he just hook up AC200-240 to pins 1and 3 and see if the motor works?
                                        • Th3_uN1Qu3
                                          Cooling upgrade on refrigerator. If it works, it ain't stupid!
                                          by Th3_uN1Qu3
                                          I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
                                          Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
                                          Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
                                          09-03-2023, 06:29 AM
                                        • connorcc2005
                                          Kenmore refrigerator adaptive defrost timer fix. Part: AP4909015
                                          by connorcc2005
                                          I have a 20 year old Kenmore side by side refrigerator that was acting up with the following issues:
                                          • Evaporator coil in the freezer was frozen up.
                                          • Unit was still holding temperature
                                          • Evaporator fan would run 2 to 3 seconds on then shut off only to repeat.
                                          Defrosted the evaporator coil and began testing. Defrost heater ohmed out good. Defrost thermal switch on the evaporator line in the freezer tested good. Once the evaporator coil was defrosted, the freezer and fridge worked but the fan continued to cycle on and off continuously. I suspect the evaporator coil was destined to freeze up again...
                                          03-20-2024, 01:14 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • CG2
                                          Liebherr Fridge Freezer KGT 3456 not working
                                          by CG2
                                          To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                          01-25-2023, 02:12 PM
                                        • mikey5791
                                          Help repair Panasonic fridge not cooling
                                          by mikey5791
                                          Hi all forum members,
                                          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                          07-16-2025, 02:01 AM
