VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
  • rebelkustoms
    • Sep 2015
    • 150
    Hi all, got a new set to look at. This one is a Vizio D60-F3 it has no standby light, wont power on and has no pi or sound. I have checked continuity in the fuse. I checked the pinouts to the motherboard several times and I am getting no voltage on any of the pins. Guy who gave it to me told me it was turning on then going off and then it stopped coming on. There are pics of the model and powerboard. Thanks
    Re: VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
    Can we see the pictures of the whole backside of the TV showing all the boards so we can see how all the boards are connected together?
    • rebelkustoms
      • Sep 2015
      • 150
      Sure, sorry
        Are you getting about 160VDC when measure right between the two legs of main filter cap C2 (no need to turn the TV ON)?
        • rebelkustoms
          • Sep 2015
          • 150
          Yea both caps reading about 170V
          • R_J
            • Jun 2012
            • 9579
            The first thing I would do is remove the power supply from the tv and inspect or resolder the connections on the transformers, they like to develop poor connections and go intermittent.
            Also check the solder connections on any of the components mounted to the heat sinks .
              Show us good clear straight shots pictures of the whole bottom side of the power supply board.
              • rebelkustoms
                • Sep 2015
                • 150
                Here is PS shot.
                • nomoresonys
                  • 12216
                  • U.S.
                  You probably already did, maybe check those 2 diodes D102, D106, D103, maybe heat up your electrolytic caps with a hairdryer and see if it wants to start up if it does, you probably have a bad cap or 2 or more, test power cord for continuity. Seems like the caps should be ok tho, they've only been out for 2 years.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    There seems to be a residue of some sort around the large transformer in post #8 poking through the circuit board. Can you see where it has come from?
                    • rebelkustoms
                      • Sep 2015
                      • 150
                      The residue just seems to be glue residue that seems to be all over the board. not specific to that area.
                      • rebelkustoms
                        • Sep 2015
                        • 150
                        checked the diodes, they are all reading within range. just for fun i desoldered that line of caps on the low volt side and tested them with my esr meter and they seem to be ok.
                        • rebelkustoms
                          • Sep 2015
                          • 150
                          I resoldered all 3 transformers, and all the mosfets with heat sinks on the board. still no luck on any of these fixes. i'm getting no stand by light or power to the main set of pins.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Have you checked the 4 diodes under the heatsink. D1, D2, D7 & D8. They appear to supply power to the set along with the bridge rectifier DB1
                            • R_J
                              • Jun 2012
                              • 9579
                              You have 170vdc across the main cap, now with negative meter probe on cap negative (M10), Check for voltage on R12, on the end sticking out from under the heatsink. If you have 170vdc on R12, (leave negative probe on M10) check the voltage on D106 cathode (white mark on diode)
                              Also check the voltage on D3 cathode
                              • rebelkustoms
                                • Sep 2015
                                • 150
                                I have 173V between M10 and R12. M10 to D106 Cathode I get voltage jumping all over, like 3,5,8,9,etc. it never stabilizes.
                                • rebelkustoms
                                  • Sep 2015
                                  • 150
                                  I checked these last night, I didnt take them out of circuit but they all are testing around .5.
                                  • R_J
                                    • Jun 2012
                                    • 9579
                                    Are you getting any voltage on the +16VS on plug CN201? What about the voltage on D3?
                                    Can you read the number on U1?
                                    The voltage on D106 is jumping around because the ic is likely operating in burst mode.
                                    • rebelkustoms
                                      • Sep 2015
                                      • 150
                                      I am getting jumpy voltage all <1v on bith +16 pins. So No voltage on that.
                                      D3 is 14v
                                      I dont see a U1. is it one of the 3 U2, U102, and U402?
                                      • R_J
                                        • Jun 2012
                                        • 9579
                                        U1 is on the trace side, it is the standby ic. on the other side of D3. Check that D201 dual diode is not shorted
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
