Need LAN connection over several hundred meters - how to do this?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Here is a project I have been working on. I am supplying a company who have a license from the government to re-open the open air markets which have been closed due to COVID-19
    They have to fulfill certain restrictions to open the markets, we are currently three weeks into an eight week trial.
    The main requirements are:
    1. The temperature of every person visiting the market is taken.
    2. There is a capacity limit of how many people can be in the market at a given time, and it must be observed.
    3. Everyone must wear a mask (Actually this is the law anyway, anywhere indoors or outdoors, with heavy personal fines for non compliance).
    4. Everyone uses hand gel at the entrance.
    My part of this project is 1. and 2.
    For 1. I already supplied a mass thermal imaging system, and it's working fine. This can monitor up to 30 people simultaneously moving through a 3 meter wide entrance 'corridor' without stopping to be checked, It can measure core body temperature outdoors within +/- 0.3C as it uses a Black Body temperature reference which compensates for moving air currents etc, and can process 6000 people in 30 minutes. It give alarms for abnormal body temperature above 37.5C, or persons not wearing a mask. Carrying a hot cup of coffee etc will not trigger an alarm as it uses facial recognition and know the difference between a face and a coffee cup. It's working very well.
    For 2. They are currently using a manual system counting people in and out with a mobile phone app which gives an occupancy level. This we need to automate. And this is where my question comes in.
    This video is the system in use as it stands. My mass thermal imaging and their mobile phone occupancy app
    https://www.youtube.com/watch?v=4IfaC8jvfWI
    The venue occupancy control system I have uses two LAN cameras, one at the entrance and one at the exit. They are connected to a PC at the entrance using a POE switch and the LAN port. The PC shows a 'traffic light' on screen - or can drive external LED lights - and shows the current occupancy.
    When the occupancy reaches 90% the traffic light goes Amber. At 100% it goes Red and you must wait at the entrance until someone leaves the exit.
    This is working well at my office. The AI software is also clever enough to know if someone leaves via the entrance or enters via the exit and can still calculate the occupancy correctly.
    The cameras on the LAN are 192.168.1.108 and 192.168.1.109
    The PC is using ICS (Internet Connection Sharing) and is 192.168.1.1
    I've attached a picture which shows the setup as it is. The square camera looking thing on the tripod at the entrance is the Black Body and only needs power.
    The problems I need to overcome are as follows:
    a. The exit camera is 200-300 meters from the PC at the entrance and I need to connect it via the same LAN as the entrance camera.
    b. There are 400 market stores and a lot of people moving around between the entrance and exit.
    c. The Exit camera is not in direct line of sight from the entrance (where the PC is located)
    d. There may or may not be internet access available at the market. If there is it would be 4G but Let's assume there is not.
    e. This is a portable system. It needs to be quick and easy to set up and the actual situation can vary from one venue to another.
    So top and bottom of this. How do I do it?
    Best regards
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: Need LAN connection over several hundred meters - how to do this?
    Search for a network through electric cables, LAN adapters. TP-Link TL-PA211 Unboxing and demo AV200 Power line Ethernet adapter.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Hmm I never thought of using power line adapters - I am not sure if that would work. It is possible the power is coming from generators as these are outdoor events (but I will ask the guys)
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        [I have no idea as to your costs, budget, etc.]
        As I see it, your problem is that the cameras are high bandwidth devices to the PC. You "need" a hard connection between the PC and camera(s).
        But, the INFORMATION that you are managing is really just "how hot is this body" and "how many bodies have gone in/come out".
        This is a LOW bandwidth channel.
        Imagine locating "smarts" (a PC) at each camera (or thermal imagine sensor). Let each device reduce the data that it observes to something simple: "person in", "person out", "person too hot", etc.
        Then, look at how to exchange this information, reliably, over these longer distances. For a wired interface, you could use EIA485 at 1000 ft or more (at 1Mbps; longer for slower... hint!).
        For wireless, you could use some of the ~900MHz transceivers and just pass beeps and bops. You could possibly prototype such a system with a couple of "cordless phones" (NOT cell phones) by butchering their keypads, etc.
        Remember, you have "smarts" at each end so you can have the PCs encode and decode any signals passed over the interface -- as well as implement an acknowledgement protocol to increase your confidence in the data being exchanged (turn light RED when you lose connection or encounter malicious interference?).
        [You have to look at your resources, skillset, timeframe, etc. I'm just trying to encourage you to free your implementation from the "demands" of the camera-PC links!]
        • diif
          • Feb 2014
          • 6978
          • England
          Powerline adapters will only work on the same ring.
          You should be able to get 300m using a couple of PoE extenders.
          • brethin
            • Dec 2008
            • 1907
            Fiber is the way to go.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              @curious george and others
              I'm not prototyping this stuff, it is all off the shelf kit and software. So I can't devise my own way of using a low bandwidth channel to just send the occupancy count
              The thermal imaging camera has two channels, video (for facial recognition) and heatmap. Anyway that is working just fine as all the kit is close to the entrance. This could do clever stuff by the way - for example of someone presents with an abnormal temperature, you could use the recorded 'mug-shot' and ask the AI t then find all close contacts who were near to that person before they were symptomatic. But that feature is more for the solution I have for hotels where guests are in the same environment for a week or two.
              What bothers me about power line - they never seemed too reliable to me - plus assuming they are drawing power from the mains grid, for sure there are going to be long portable extension cables in use, and powerline adapters like to be directly into the mains sockets.
              The camera at the exit is 2 mega pixel
              Budget - well so far the system is in at around $9000 (USD) so if it costs another $1000 to get the remote camera linked across 200-300m it would be acceptable, though i would hope it was less than that - several hundred dollars possibly.
              I was thinking of using microwave link. That would still be doable if I could get the dishes above the height of the market stalls, but then probably there could be other obstructions such as palm trees - plus how difficult/precise would it be to mount and align the two dishes quickly. Maybe one omni-direction transmitter (hotspot) at the camera end and a directional receiving antenna at the PC end? Sort of a long range WiFi.
              I was trying to avoid running a very long cable but that is one way to do it. The cable would have to be laid at the start of the event then rolled up neatly in a resuable manner at the end.
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                I only suggested that as a quick/easy way to see if the technology would work for you.
                First google link: https://www.esteem.com/horizon-900-main-page/
                And what if they CAN'T access the mains? E.g., running the kit off a small genset (or even batteries!) Or, the branch circuit in one spot is entirely different from the one used elsewhere?
                I was trying to avoid running a very long cable but that is one way to do it. The cable would have to be laid at the start of the event then rolled up neatly in a reusable manner at the end.
                It's not just the hassle of deploying a long cable; what if the cable is damaged while deployed? Are you going to hoist it many feet above the heads of the attendees? Are you going to dig a trench to bury it below their feet? Will you have kit on hand to "fix" the cable if it does become damaged? (e.g., fiber requires special tools and skillset) Will the "light turn red" while the cable is being repaired? How long will that process take (imagine having to walk the length of a cable looking for kinks or cuts!)
                It's one thing to run a cable (copper or fiber) out along the ground in your own yard or in a business (where folks have an incentive not to earn the wrath of their employer by carelessly damaging it) but another thing entirely to hope "attendees" will respect your kit.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Hi George
                  And what if they CAN'T access the mains? Yep exactly that
                  TBH You have come up with a lot of the problems I was already facing!!
                  The 900MHz solution looks interesting. The lower the frequency the better this could work. I will contact these guys and see what they can suggest
                  • petehall347
                    • Jan 2015
                    • 4451
                    • United Kingdom
                    seems a bit flawed as all hot people are not infectious .
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      And folks who are infectious aren't necessarily hot!
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        There are other frequency bands that may also be available to you (sorry, I don't know what's "legal" where you reside).
                        You can also buy "extended power" WiFi access points. These aren't legal in the US but may be where you are. In free air. locating one centrally may easily allow you to bridge the distance between "devices" (again, I'm thinking along the lines of separate in and out "devices")
                        • petehall347
                          • Jan 2015
                          • 4451
                          • United Kingdom
                          indeed so
                            • 31303
                            you should do the rightious thing and turn down the job rather than assist in this slow communist takeover.
                              • 22241
                              Come on,can you please keep your conspiracy theories in the VIP section.
                              • dicky96
                                Sun Seeker
                                • Mar 2017
                                • 1825
                                • Spain
                                Sure but a fever is the most common symptom and anyone detected with an abnormal core temperature is then checked by a medical professional to see why.
                                Even if it catches a handful of cases and stops a few transmissions surely that is better than none?
                                Especially the hotel solution which continually monitors people as they walk between the rooms and communal areas each day, unobtrusively of course. And then should someone become symptomatic of anything that causes a fever during thier stay, it is easy to isolate that person and find everyone else they have been in close contact with. Not to mention other things like with the facial recognition and recording you would know who was in the hotel residential or communal areas if there is an emergency such as a fire. By the time emergency services arrive you could tell them who is not in the resort, who made it to the fire meeting point and who is missing. Time saves lives.
                                The AI can also spot people reserving sunbeds with towels at 7am - if you so wish LOL
                                So really, if you can have this technology why not? The governent here decided it is necessary to reopen outdoor events that have been closed for months and given the choice of this or nothing what is the better? Also which hotel would you prefer to holiday in? The one with this technology or the one without, given the choice.
                                Also it ain't even expensive... 400 market stalls all paying an extra 25 euros on the months rent (for one month only) = 10K euros and they are able to trade again.
                                They take COVID very seriously here - this may be why we have only 20 active cases out of a population near to 1 million (more including the tourists and six month winter stays who are here)
                                stj.
                                Consider this question and answer honestly:
                                If the politicians decide to implement this technology, would you prefer to the the one who sold it to them or the one that didn't?
                                Rich
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  The problem I see with checking temperatures, PCR tests, vaccines (when they materialize), etc. is it leaves folks with a false sense of security: "I'm not running a fever so I must not be sick".
                                  Each time I go to the library or a medical provider's office, they check my temperature (noncontact thermometer). It ALWAYS reads a degree or more lower than my actual temperature. Huh??
                                  A more effective solution is widespread testing -- often. "You were negative the last time we tested you -- but, positive now. Someone (or something) you came in contact with is the likely source and everyone that you've come into contact with is potentially infected."
                                  Until someone notices an infection spread at one of these events DESPITE the precautions. You then have to worry that vendors will wonder why they are paying for something that isn't working; or, customers deciding that the precautions still don't guarantee their safety.
                                  Remember, folks already are living with uncertainty. You're selling them a different TYPE of uncertainty, not certainty itself.
                                  I wouldn't want to bet a business on it! Just like a potential vaccine -- it MAY turn out OK... or, it may prove to be a flop and leave you with an investment and no customers.
                                  "Don't quit your day job."
                                    • 31303
                                    stj.
                                    Rich
                                    Honestly, i would not want my name associated with it in the slightest.
                                    MOD EDIT: Please keep to the thread topic.Post what you like in the VIP forum.
                                    • dicky96
                                      Sun Seeker
                                      • Mar 2017
                                      • 1825
                                      • Spain
                                      Well seeing as this is all off-the-shelf kit and software, just configured to do a job that is 'en-vogue' right now, risk isn't really a problem as there is no R&D budget as such. The system on the video I posted is the 'prototype' if you like on an 8 week trial (tomorrows market is week 4) and that's already been payed for, so I most certainly ain't out of pocket.
                                      The only risk really was buying the kit for the first system and getting the word out to the right sort of people. Nothing ventured nothing gained yeah?
                                      If the trial is considered successful I can soon get enough more kit of more systems - to order
                                      • dicky96
                                        Sun Seeker
                                        • Mar 2017
                                        • 1825
                                        • Spain
                                        @Curious George et al
                                        I think the answer to this is somewhat geographic. You have to realise I live on an island that depends on tourism for 80% of GDP. It is one of five main tourist islands in the Canary Islands
                                        We never recovered from lock down, many businesses and hotels have not reopened since March and there is a huge amount of unemployment here now.
                                        We opened up up for tourism at the end of June for mainly domestic tourists from the Spanish mainland, and ended up back in lock down at the start of August due to a massive surge in cases.
                                        The markets we are trying to re-open have been closed since then
                                        Now the government say that from 12th November, no one is allowed to arrive on the islands without taking a negative covid test 48 hrs before arrival, and that also applies to residents who leave for more than 7 days.
                                        What they are trying to do is make this a fortress where no-one can come here without testing negative first, and when here you follow restrictions to stop locally spread infections
                                        Probably this the only way our economy can survive, and if it works we become a play ground for those wanting to take a holiday in the safest environment possible
                                        I have a small part in this now and to be honest i feel proud to have that opportunity
                                        Rich
                                        • Woodsworth
                                          PS3 CECHC03 60GB YLOD Troubleshooting
                                          by Woodsworth
                                          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                          START
                                          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                          03-19-2024, 07:58 AM
                                        • budwich
                                          Lithium 12v tool battery charger... no negative connection?
                                          by budwich
                                          I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                                          03-18-2025, 09:12 AM
                                        • Demetrio87
                                          Legion t 5 front audio panel connection problem
                                          by Demetrio87
                                          Hi everyone, I hope someone can help me solve my problem, I have the case of a legion t5 where I have installed an asus tuf gamig a520m-plus motherboard, the audio connection cable on the case is an F_audio connector with 14 PIN , on my new motherboard the connector is a 10-pin AAFP, I saw that there are adapters on sale but at the moment I have no way of having them available in a short time, I made several attempts and managed to listen from the front headphones, only that there are some problems, the headphones are only detected if the microphone is connected, I definitely got confused with...
                                          12-08-2023, 12:06 PM
                                        • Nikan.e
                                          Inno 3d RTX2070 not detected - no I²C connection
                                          by Nikan.e
                                          Greetings and Salutations!
                                          I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                                          The faulty DrMOS was removed, and the burned PCB area was milled away.
                                          All voltages are now good, but the GPU is not being detected.
                                          I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                                          I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                                          I thought these pins were used for communication during startup?!?
                                          On all...
                                          03-30-2025, 07:21 AM
                                        • ktmmotocross
                                          Lenovo Legion 5 Pro 16ACH6H bad crystal?, but now wont program. connection lost after 5 seconds
                                          by ktmmotocross
                                          Hello.
                                          Have this Lenovo Legion 5 Pro 16ACH6H that came with no start, only powerbutton light. i reflash bios and ec. no change. i replace one of soc cpu crystals and laptop start to work. but when i assemble it, keyboard not work. so i reflash back bios but when i try to reflash ec i get write error and now i connect to it but always read/write error and connection lost after 5 seconds.
                                          IC is ITE8277E - 256 programmer is vertyanov. i try to change back that crystal but still the same
                                          NM-D562 rev3.0
                                          sn- PF31EESB
                                          any ...
                                          01-22-2024, 05:33 AM
