55HT1U possible bad tcon
  • Jeryswan
    • Mar 2020
    • 39
    I have a 55HT1U that is displaying an image that is distorted and somewhat "staticy"
    My anticipation is that the T-con is bad. what do you guys think?
    Re: 55HT1U possible bad tcon
    What does it look like with video source?
    What is the history of the TV?
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      looks split in the middle . no idea if its safe or even possible to swap the feeds to the tcon to see if its main or tcon . i would clean connections first
      • Jeryswan
        • Mar 2020
        • 39
        Here is what it looks like with a video source. One half is still very gritty. The other half is almost indistinguishable. While there is no video, there is a white line down the worse half.
        • Diah
          • Feb 2013
          • 6460
          panel damage..
            Panel problem. Do you know the history of the TV? Used TV?
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
