Sharp LC-50LB371C LED TV VERTICAL LINES
  • TV HELP
    • Nov 2020
    • 13
    I’m new here and would love to get some help....I have a 5 year old Sharp LED tv with vertical lines.
    So far I have removed and cleaned most of the ribbon cables with no change.....any help with the next testing steps such as voltage checks or? would be highly appreciated.
  • TV HELP
    • Nov 2020
    • 13
    Re: Sharp LC-50LB371C LED TV VERTICAL LINES
    Could it be the t-con
    • nomoresonys
      • 12306
      • U.S.
      I think it's a bad tab bond, try tapping on the bezel, NOT the screen where the line is, see if the line goes away or changes any.
      • neilc6
        • Nov 2015
        • 1550
        Only repeating lines/patterns may be tcon issues. Single random vertical lines or bands are bad panels.
        • TV HELP
          • Nov 2020
          • 13
          When I disconnect the 2 ribbon cables that leave the T-Con board and go to the panel the lines go away......not sure if this means anything?
          • TV HELP
            • Nov 2020
            • 13
            How do I test the T-Con board to confirm it works or not?
            • nomoresonys
              • 12306
              • U.S.
              Try wiggle or shake the video input cables, see if that helps.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4499
                • Italy - Milan
                if you detach tcon outputs its normal that lines go.away since there is no more signal, locate the tabs where appears bad columns, then put a shim under them, then warm the back of the chip so on the amber side with a sokdering iron
                • TV HELP
                  • Nov 2020
                  • 13
                  Can you please send a picture of where I do this
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4499
                    • Italy - Milan
                    defenately not, i'm at hospital now..
                    • TV HELP
                      • Nov 2020
                      • 13
                      I hope you are ok!
                      • TV HELP
                        • Nov 2020
                        • 13
                        Are you in Milan Italy? I have been there!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4499
                          • Italy - Milan
                          yes.. so basically,, if you detach tcon from the large screen boards , then you flip them you see the green part of the tab where there is a chip, ok you must put a shim under it provisional, then you put eveeverything normal and you warm under the chip especially in the zone that makes appear again the missing lines, so this test at tv switched on, i have near reapaired one this way.
                          • TV HELP
                            • Nov 2020
                            • 13
                            Any other ideas?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4499
                              • Italy - Milan
                              Buf why other ideas? I have given you an idea, you have done what?...
                              • TV HELP
                                • Nov 2020
                                • 13
                                I want to try your option I'm just not sure exactly what you want me to do
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4499
                                  • Italy - Milan
                                  sorry i can't explain it better
                                  • TV HELP
                                    • Nov 2020
                                    • 13
                                    Thank you very much for your help!
                                    • TV HELP
                                      • Nov 2020
                                      • 13
                                      • TV HELP
                                        • Nov 2020
                                        • 13
                                        I took part of the bottom bezel off and discovered a sticky substance on one of the I believe their called tab bonds maybe someone spilled something .....could this be an issue?
                                        I will be cleaning the area up and testing.
                                        • Stanley1843
                                          Screen Display Vertical Multicolor Lines
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          Sadly it has vertical lines at the left and one line in the middle-right.
                                          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                          I have factory resetted the TV as well but also with no luck.
                                          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
