Does power supply have to have metal case?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I was thinking of making custom case for power supply. It currently has one small 6 cm fan which needs high rpm in order to keep it cool. However this makes it noisy. I had a thought that I would 3D print a larger case that have 2x 12cm fans that I would run with low RPM to keep them quiet. I figured that it is easier to 3D print a new case than do it from metal because I dont have tools to make precise cuts, bend it to right angle weld screw mounts and so on.
    Would something be wrong if I 3D print plastic case instead? For example is it required to shield from radio waves or something or will it work just as fine in plastic case?
    Some screws that connect PCB to case are connected to fault ground. I guess these I just have to wire connect to ground?
    Has anyone ever attempted to build a custom case? Any success?
    • Jul 2011
    • 6070
    Re: Does power supply have to have metal case?
    Is this a computer switching power supply mostly in metal cases ( I do not have an answer for you about this type of switching power supply I do not want to give you the wrong information )
    Or is just a switching power supply because this type of switching power supply are mostly made with plastic enclosure
      • 31303
      switching power supplies are in metal boxes for screening,
      not to protect them, but because they are the source of rf noise.
      if you dont use radio or give a shit then it will be fine in plastic - they used to sell coloured acrylic shells to customise pc psu's.
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        aluminium tape works apparently
        • LearningToRepair
          • Jul 2020
          • 35
          It's general purpose SMPS from china. You know one that is used for LED lights, 3D printers etc.
          How well do those frequencies go through wall? Would it kill neighbours radio/wifi behind concrete wall?
          What's the exact frequency? The same frequency as switching?
          Aluminium tape sounds good idea.
          I dont even have radio at home so I have no idea how to verify if I have enough layers of aluminium foil. And if I put 2 large fans on top then the top of it would leak anyways.
            • 31303
            switching frequency - something usually between 30KHz and 1MHz + harmonics.
            range will be short - 10's of feet, but if you have a radio operator next-door they will be effected because they use long-range ultra-sensitive antenna's
            • LearningToRepair
              • Jul 2020
              • 35
              Thanks.
              For humans it wouldn't do anything? I guess it wouldn't be much stronger than wifi/mobile networks that are already around us?
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                What you hear about RF being injurious to humans is all nonsense by those who don't understand how it works anyway.
                It won't do anything to humans unless it gives off an audible whine. Then it'll give you a headache at worst.
                Follow the white rabbit.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  However, concentrated 1KW RF pointed directly at a person could do something...
                  Same could be said about connecting 120VAC and passing 8 amperes...
                  Fear of the unknown. RF, wireless communication, and microwave ovens are voodoo for most people out there and thus is "scary..."
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    MMmmhmm. So ive noticed.
                    People don't know math. Else they would understand magnitudes.
                    Thanks broken school system!
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • shadow666
                      ASUS N43SM with Nvidia GT620M crash after touch metal case
                      by shadow666
                      i have a asus N43SM i7 2th gen and i have a big probelm
                      After hitting the metal part of the touchpad or the sides of the mouse is metal, the system locks and the image crashes !
                      disassemble notebook and this cover on top picture I insulated all the bases on which the screw is fastened so that static electricity does not cause this problem again but not working !
                      Sometimes, when I didn't work with the notebook for a few minutes, after I touch the touchpad, the image confused​ and the system locks ( See Down Picture). I have to turn the system...
                      01-05-2025, 08:45 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                      ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 10:50 PM
