HP 15 LA-C701P not turning on
  • lapfix
    • Mar 2020
    • 2750
    • my workshop
    Hello friends
    I got this motherboard that didn't turn on.
    No damage , no liquid..
    When i plug in the charger -PSU-the power led is on with 0.004 amp taken.
    3/5valwp and 1.35vVP comes after power switching.
    When i press the power button nothing happen with 0.006 amp taken ,3/5valwp are present for a couple of seconds , but no +1.35VP for Ram .
    With diode mode i take all my measurements in each coil and all ok , no short to ground.
    Try to clean me region for bios still the same.
    this is the voltages taken from UK1 = KB9022Q
    104 = MAINPWON = 0/3v
    110 = EC_ACIN = 3.3
    112 = EC_ON = 3.3v
    100 = PCH_RSMRST# = 0v
    114 = ON/OFF# = 3v/0/3
    13 = PLT_RST =0v
    95 = SYSON =0v
    Did this lap need a IO dump!
    what to check else..thank you
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=60764
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15 LA-C701P not turning on
    RSMRST# has to be 3V. Check LIDSW# signal present or not?? RTC reset checked??
    • lapfix
      • Mar 2020
      • 2750
      • my workshop
      Thank you mcplslg
      115 = LID_SW# = 3.3v
      PCH_RTCRST# and PCH_SRTCRST# = 2.96v
      For PU3 the 2 enable signal not present = EN_1.35VP and EN_0.675VSP.
      The SUSP# and SYSON
      • piernov
        • Jan 2016
        • 4437
        • France
        Did you follow power sequence?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its useless to measue SUSP#,SYSON or PLTRST when you dont have RSMRST#. Unless PCH_RSMRST# is de-asserted, PCH is not going to release SLP_S5 and so on. So those signals like susp# or pltrst are not going to rise. Dont waste your time measuring them. Need to check why RSMRST# is not 3V.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            +3V_PCH Present??PM_SLP_SUS# present??PCH_PWR_EN??
            • lapfix
              • Mar 2020
              • 2750
              • my workshop
              Techtiger : yes...until i didn't get my 1.35vp
              mcplslig : +3V_PCH not present .
              Q30 :
              Source = 3.364v
              Gate = 3.334v ..i think for Pchannel must be 0v when Q31 is On..but it isn't
              Drain = 0V
              Q31 :
              Drain =3.300v
              Gate = 0v..that's my pb !
              Source = ground
              • piernov
                • Jan 2016
                • 4437
                • France
                You didn't list the most important one… PM_SLP_SUS#.
                • lapfix
                  • Mar 2020
                  • 2750
                  • my workshop
                  Sorry piernov , ys forget to test this ; PM_SLP_SUS#= 0V
                  PBTN_OUT# pin 122 = 0v than 3v
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    If PM_SLP_SUS# is 0V you are far from getting to an S3 state to get RAM power rail. As you can see from power sequence, RAM voltage turns on at step 11 while you're not even getting step 5…
                    Check votlage on RTCRST#, SRTCRST#, INTVRMEN, DSWVRMEN, DPWROK, PM_BATLOW#, ACPRESENT going to the PCH.
                    Can you clarify what this means?
                    • lapfix
                      • Mar 2020
                      • 2750
                      • my workshop
                      Agree with your diagnostic..i will take the voltages of the others
                      Can you clarify what this means?[/QUOTE]
                      0V before switch on,...3v after switch on
                      • lapfix
                        • Mar 2020
                        • 2750
                        • my workshop
                        Piernov , merci l'ami.
                        Try to find PM_BATLOW# , It was RPH1 Close to Cpu so i take out the heatsink and surprise : YC1 was broken ( under the heatsink)...change it with the same one and all voltages rise up , the motherboard alive but no screen , just i reflash bios with the old dump and all is OK.
                        A big thank to mcplslg123 and Piernov.
                        • jaroslav.psenicka
                          Lenovo Yoga 2 13 LA-A921P - missing SYSON
                          by jaroslav.psenicka
                          I have a LA-A921P here on AC adapter
                          • power LED on
                          • button SW1 (power) pressed
                          • the CPU gets warm
                          • fan not spinning
                          • no dead short found anywhere
                          • +5VALW/+3VALW present
                          • DDR_VTT_PG_CTRL is 5V
                          • SYSON is 0V
                          the +0.675VSP and +1.35VP is missing, assuming because of missing SYSON signal
                          SYSON is not shoted to ground
                          the SYSON is generated by U51 hope it's not it
                          Is there anything i can test?
                          Many thanks,
                          -jp...
                          04-16-2024, 06:38 AM
                        • mat2k
                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                          by mat2k
                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                          12-01-2024, 11:00 PM
                        • Sparklingx
                          HP 450 g1 keeps turning on even tho shutdown/sleep
                          by Sparklingx
                          HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                          09-23-2024, 12:34 AM
                        • khelane
                          Satellite PRO A50-A Not turning on after turning off Windows
                          by khelane
                          Hello
                          A device with specifications
                          Toshiba Satellite PRO A50-A is here to replace the hard drive.
                          The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                          The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                          04-20-2023, 06:28 AM
                        • Rabit
                          VX3276-2K-mhd-2 Random Turning off
                          by Rabit
                          Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                          When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                          This can be signs of bad capacitors causing overheating PSU ?
                          06-17-2024, 09:30 AM
