Inverter welder help
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. It's been a while since I've actually repaired anything, so today I have something I haven't worked on before: a friend of mine gave me this small inverter welder to look at. It powers on, but doesn't work.
    I took the cover off and immediately noticed the problem: two dead G40N60 transistors, along with some SMD resistors in what I think is the gate drive for the trannies. One IGBT is dead-short, the other reads fine, but it's missing a chunk of the casing, plus its SS14 diode is also gone, so it's safe to say we'll be replacing both.
    The SMD resistors are by far the biggest issue, since I'm not able to make out what value two of them are. I can see 5R1 on one pair, but the other is completely gone. All I can see is a 1 and a 0, but nothing in between....if I had to hazard a guess, I'd say it's 150, but that could be totally random....
    The welder is an ESAB MMA 300 if it matters at all. Without a schematic, I was hoping someone may recognize the circuit and offer some approximation to those values, since it looks "generic" enough and I recall seeing this shape and size under other brand names too on the shelves...it may not even be worth repairing it, given how expensive those transistors can get, especially since there's the risk of blowing them again. It's almost identical to THIS one, except it's got an ammeter at the front. The blurry schematic does actually show those 5R1 resistors in the gate drive on the far right of the page there, but the schematic is not clear enough to work out what IGBTs it uses, so I'm not sure if those values would work in mine as well. Of course, I'm grasping at straws, but this would mean the blown resistors are 20R ones, which comes close to the 150 value I'm betting on...
    Wattevah...
    • 31138
    Re: Inverter welder help
    so it's just a stick welder, not even a mig?
    those things are sooo cheap now that it's not worth the time.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Yes, it's a stick welder - tiny too. It's like a small UPS
      I'd hazard a guess it's the dust buildup that killed it: there was a LOT of dirt caked on the legs of the two transistors. It's not the fluffy dust you get on the inside of electronics or PCs - it was more like dust that got moist and turned into mud which then dried off....that kind...
      Wattevah...
        • 31138
        the crap may even be conductive,
        remember before welding you clean the surfaces with a grinder!!
        metal dust!!!!
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          metal dust!!!!
          + fan on the back to help suck it in
          Wattevah...
          • petehall347
            • Jan 2015
            • 4429
            • United Kingdom
            needs an air filter then
              • 31138
              needed an air filter - not any more!
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8286
                my take on it is a 750, as being 75 Ohm.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Could be...what's the worst that can happen
                  Now that I look at it more carefully, it could be a 7 after all, the way the line seems to curve ever so slightly...
                  Wattevah...
                  • petehall347
                    • Jan 2015
                    • 4429
                    • United Kingdom
                    be better buying a new welder and adding a filter
                    then maybe looking at values of unknown resistors .
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8286
                      Nothing. The gate drive resistor just limits the current. Common to see up to 100 Ohm resistor there.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        So I guess if it's too high, the gate would be insufficiently driven and the transistor would overheat (linear region ???).
                        If it's too low = too MUCH base current...
                        Wattevah...
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8286
                          Yeah, the gate resistor has to be selected. All depends on the IGBT, switching time, etc...
                          However, yours look like 750 to me, which is 75 Ohms.
                          • Crystaleyes
                            Inverter Welder Strangeness
                            by Crystaleyes
                            Hola peeps.
                            I'm placing it in this topic, because from what I can see, it is essentially a modified SMPS, but please move if there is a 'correct' forum section.
                            Recently, I bought an essentially brand new, but defective, 155 amp inverter welder.
                            The unit would turn on fine, with the digital display and fan doing their thing, however when attempting to strike an arc, the rod would merely spark or just get stuck onto the steel.
                            Now I know that many (if not most) in here would simply not have bought it, but I am still learning this trade...
                            03-27-2023, 04:04 PM
                          • edugimeno
                            Repair an inverter welder
                            by edugimeno
                            Hi! I got this (see pics) welder which wouldn't work at all at the welding leads. I tested output voltage and got 0v
                            Opened it and found a diode that was busted (missing resin...). Ref RHRP1560.
                            I believe this diode protects one of the IGBT's that drive the transformer
                            His twin diode wasn't physically damaged but measured OL on both polarities so both will be replaced
                            Now, after watching some videos on welder repairs, it seems that the IGBT's usually fail together with the diodes, is this true? I tested IGBT with multimeter-diode mode, still on board, and got OL on...
                            07-19-2023, 07:28 AM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • TinkerTron
                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                            by TinkerTron
                            Hey everyone,
                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                            Instead, here's what's been bugging me so far:
                            The schematic...
                            03-06-2025, 02:03 PM
                          • spleenharvester
                            Reverse engineering of DoCreate DHJ567 handheld spot welder
                            by spleenharvester
                            Hello everyone
                            I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                            Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                            05-08-2025, 02:52 PM
