How is called that compound that glues components on the PCB?
  • buchman
    • Aug 2015
    • 283
    • greece
    If someone can post a link, I will appreciate that.
    • 31134
    Re: How is called that compound that glues components on the PCB?
    solder??
    • R_J
      • Jun 2012
      • 9578
      I agree, solder... or do you mean this:
      SMD assembly adhesive https://www.panacol.com/adhesive-app...r-smd-assembly
      • buchman
        • Aug 2015
        • 283
        • greece
        No guys, not solder. The white stuff that looks like silicone/ETC or it is silicone?
        I am not sure that it is a regular silicone, I know that it's not supposed to be conductive.
        • buchman
          • Aug 2015
          • 283
          • greece
          I attached a photo.
          • petehall347
            • Jan 2015
            • 4429
            • United Kingdom
            thermal adhesive
            • R_J
              • Jun 2012
              • 9578
              That is just silicone
                • 31134
                not exactly, it's NEUTRAL-CURE silicone.
                cheap crap has acid in it that eats the plating off wires & stuff.
                • buchman
                  • Aug 2015
                  • 283
                  • greece
                  No, I don't need a thermal adhesive, I need some kind of silicone to glue a capacitor that I have replaced.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8285
                    dont use any silicone that smells like vinegar. i use black rtv, since it is easy to get for me.
                    • petehall347
                      • Jan 2015
                      • 4429
                      • United Kingdom
                      use hot glue if it doesn't run hot
                        Electronics grade Silicone:
                        I.E. https://www.amazon.com/Clear-Electro.../dp/B07MKBBQTC
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5008
                          • New Zealand
                          It's not just cheap silicone that uses acid. Most use acid. In my local hardware stores, EVERY silicone uses acid even the most expensive brands.
                          Some even say things like "Organic Acid" or "Low Odor" but those are still not suitable for electronics!! They are all designed for building, roofing, bathrooms etc.
                          It must be Neutral-cure designed for electronics, indeed.
                          -David VanHorn
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            I just bought some of this stuff for attaching heat syncs to chips ... and I could swear that any attempt to rip the heat sync off the chip once this stuff cures, it'll probably rip the chips face off before letting go... lol
                            sigpic
