sony kdl 40x 3500 no backlights
  • jimbofz
    • Apr 2013
    • 539
    • uk
    this oldie works fine , good pic and sound for its age
    but has intermittent backlights at switch on
    led turns from red to green
    when the fault is present there is sound via scart
    ive replaced caps in psu which had poor esr readings and soldered up
    then i soldered up the DF1 board above the psu ,i then removed the cover on the inverter board ,tested the small tx s and compared the resistances in case one was causing the backlight to shut off .
    this model uses ccfl and inverter board.(sony call it ballancer board )
    from the service manual the voltage on the pin marked inverter error reads 0volts ,it should be 3.1v .
    the problem is most of the time it comes on as normal
    when the fault is there all the secondary supplies from psu are good
    has anyone had experience of these early models that you could share please
    the inverter board is ssb400wa20s also used in some samsung models
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: sony kdl 40x 3500 no backlights
    There are a lot of lamps and they do start to fail as the set ages.
    Can you plug in a usb stick with just a white jpeg picture and look carefully to see if you have any dimmer horizontal sections that would line up with the CCFL tubes. They tend to dim orange/yellow as they age.
    If the fault is the inverter board then there's a cheap replacement from https://tinyurl.com/y4zsv2sl
    Personally I would think that the tubes now 13 years old have aged and one or two are at the point of complete failure.
    • jimbofz
      • Apr 2013
      • 539
      • uk
      thats a bargain i will order it once ive completed diagnosis
      im an old codger who likes to work to component level when possible.
      ive tried it this morning and the fault is present
      so im in with a chance .
      i cant measure any small a/c volts on the i/p of any of the tx s on inverter board
      according to a youtube vid i watched:
      Troubleshooting LCD Backlight Failure Samsung LNT-4066 by norcal715 .
      i should measure .2v ac on pin 2 of each tx
      could it be a supply missing?
      from df1 board (above the psu board )
      what do you think?
      by the way i tried to remove the inverter board from tv but its solid stuck ,
      is this normal,do you have to prise them out ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have a good look at this video which could be useful to you
        https://www.youtube.com/watch?v=oE6K4xBVweA
        They are connected to 20 odd CCFL tube sockets so they tend to be very tight trying to remove them. I prise them out little by little first top then bottom then top then bottom, repeated and be very carefull not to lift them until clear of the CCFL sockets or the circuit board tabs that connect into the tube sockets will break.
        • nomoresonys
          • 12306
          • U.S.
          Maybe this other Norcal video will help: https://www.youtube.com/watch?v=8oZnSleucJ0
          • nomoresonys
            • 12306
            • U.S.
            ""from the service manual the voltage on the pin marked inverter error reads 0volts ,it should be 3.1v ."" Maybe double check that, on many tvs you don't have a problem UNLESS voltage shows up on that pin.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              when the tv was on working fine the 3.1v was present ,
              when no b/l ov .
              quote from manual:if theres an error in supply to ccfl ,pin 4 of cn6706
              goes low. thanks for your help ,as i write this tv is in fault condition with 0v
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Looking at the photo from shopjimmy it appears that it's pin No 3 of each transformer that connects the lamp error voltage to the diodes
                • nomoresonys
                  • 12306
                  • U.S.
                  Ok, that one must go low, sure looks like an inverter issue then, did you try the testing from link in post #5?
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    yes the norcal video posts are very useful,
                    i definitely cant get any volts on inverter board tx s tried on a/c and dc with peak hold .
                    my stomach told me it was time for lunch, and ,yes youve guessed it ,when i returned it came on .
                    at least i was able to confirm that the cathodes of the diodes all have 2v on them (lamp error voltage)
                    so :when working ballancer error 0v
                    the invertor error 3.1v
                    the backlight on 3.2v
                    i also switched to another i/p with no signal, turned brill to max , and had a good look at display ,theres no dark horizontal stripe
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      i have removed the inverter board ,and its clear one of the tx has been under stress as the board is discoloured see pic
                      its the 4th one along marked with arrow in pic .
                      im going to remove it and link it out just for test purposes ,
                      to see if the fault clears .
                      although im not totally convinced ,because when the fault is present theres no volts at all on the primary side of the tx s
                      i suspect the ccfl its connected to, is drawing more current than the rest.
                      the tx measures exactly the same as the others.
                      sorry about the shadow on the pics
                      • nomoresonys
                        • 12306
                        • U.S.
                        Maybe check D117, see how it compares to the others.
                          Just FYI:
                          https://www.badcaps.net/forum/attach...9&d=1610795611
                          This is Inverter board which produces High Voltage and feeds the Balancer Board which the lamps are connected to..
                          https://www.badcaps.net/forum/attach...0&d=1610819201
                          What are the Voltages on
                          VCC (DCV)
                          FB (ACV, in mVAC range)
                          OLP (DCV)
                          LD (DCV)
                          You also should try setting the backlights level (Not Brightness) down to 50% to see what will happen.
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            will post voltages ,
                            but at the moment tv is ok i will try it again later
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              d117 tested good ,same as all the other diodes on each pair of tx s
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  Originally posted by budm
                                  Just FYI:
                                  VCC (DCV)
                                  OLP (DCV)
                                  LD (DCV)
                                  here are the voltages when b/l is off:
                                  VCC 12VDC
                                  FB 0V A/C OR D/C
                                  LD 12V
                                  OLP ?cant find a reference to this is it over level protection?
                                  inverter error .004v
                                  ballancer error 0v
                                  these voltages were taken with fault present .
                                  i set the b/l to 50%.
                                  i then removed the tx that was causing the ballancer board to be discoloured
                                  i linked out pin 1 and 4 and it has not yet failed to start up YET
                                  i keep trying it every 4 hours ,i intend to refit the tx and see if fault returns
                                  i will post results thanks
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    fault returned
                                    OLP volts on balancer board 0v
                                      Service manual for
                                      SONY KDL-40X3500 KDL-46X3500 KDL-52X3500 CHASSIS FIX2
                                      And Backlight topology.
                                      According to the service manual, the OLP pin is not used.
                                      Is the section of the DF1 board where the CN6708 is has dark marking due to heat or that is the shadow?
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        • uk
                                        the panel pic sadly was just a shadow . see aditional pics ,
                                        ive left the link on for the time being .
                                        thanks for the manuals .
                                        a strange thing this morning ,
                                        although the tv came on as if there was no problem,
                                        when i used the sby button on TV the pic and sound went off but i still had a feint raster ,ie the backlight stayed on .when faultfinding for no backlight i always use a scart i/p so i can confirm sound is present .it saves confusion .so the sound went off as did the pic info .
                                        when following the flowchart for backlight faultfinding , (i know they can sometimes lead you up the garden path)
                                        if 3.3v missing at cn6153 pin 3 suspect au board (main board)
                                        perhaps i should turn my attention to the main board ? any thaughts please
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
