Need Asus B450m-a prime bios .bin dump
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8342
    I need a more recent Asus B450m-a Prime bios dump in .bin format, so I can flash the SPI directly with my programmer. The main board won't POST anymore. I did find a couple of old dump files, but nothing recent.
    Thanks in advance!
  • peste
    • Dec 2016
    • 13655
    • ROMANIA
    Re: Need Asus B450m-a prime bios .bin dump
    Thanks in advance!
    before writing, make a backup copy of the original bios.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8342
      I wish I could. Took the Winbond off the board, put it into my 8 pin SOIC adapter, pin broke off. Argh!!
      Thanks for the file. Have to get a new IC and try it.
      Edit: In linux I can't decompress it properly (has errors) and leaves a 0 byte decompressed file?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8342
        Been otherwise occupied lately and I just got around to program and swap the
        Winbond IC out.
        Here is a dump of a working B450M-A bios. Mine is working once more!
        • lazaro84
          • Oct 2021
          • 1
          • mexico
          tanks for info. https://www.badcaps.net/forum/images/smilies/boink.gif
          • techcare
            • Nov 2017
            • 18
            • KOREA
            Hello this files is damaged coz can't be extracted.Can you please give the good one.Thanks in Advance.
              • 21969
              Update winrar or use 7-zip .
              • badisrep
                • Apr 2021
                • 17
                • algeria
                thank you so much
                • dimarik91
                  • Jul 2022
                  • 1
                  • Russia
                  Winbond IC out.
                  which bios version is this?
                  • DynaxSC
                    Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                    by DynaxSC
                    I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                    The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                    Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                    Usually on ASUS boards it worked...
                    06-14-2024, 03:49 PM
                  • mkdj
                    ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                    by mkdj
                    Dear all,
                    I have a ASUS ZenBook UX480F with the following symptoms:
                    I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                    I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                    10-19-2025, 04:41 AM
                  • razor_amd
                    [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                    by razor_amd
                    With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                    For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                    I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                    This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • reset1986
                    Asus prime b550m-a bios dump
                    by reset1986
                    Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                    06-22-2025, 04:17 AM
