Panasonic SU-HTB18 dead power supply (unidentified transistor)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I had a look at this soundbar from Panasonic today and it seemed like an easy enough fix, but then I got stuck.
    Have a look at that fried primary. I reckon the transistor popped and took out the current sense resistors with it before the fuse could open to cut the power. I thought I'd have a hard time figuring out what values those are, as it usually happens when SMD resistors go up in smoke, but thankfully I was able to clean them enough to read 1r60 on there, which is 1.6ohms, so that was sorted - we need 8 of those.
    On to the transistor: it's one of those mystery parts that no one's heard of. 14SL70....what could this be ? Ironically, it has a little logo there too, but all searches come out empty. I tried everything, including sourcing a service manual, but that didn't yield any results either....I'm tempted to just dig through my parts bin and pick one out semi-randomly. I'm hoping the control IC survived, because the small passives around it are fine, so I'm hoping something from the FQPF series will work in place of the original one. It claims to be a 120w amp, in case someone wants to suggest something based on past experience, enough to be in the ballpark. As always, thanks for any help. Cheers.
    Wattevah...
  • zen
    • 511
    Re: Panasonic SU-HTB18 dead power supply (unidentified transistor)
    Hi
    Regards the F E T , you can probably match up another . By the numbering seems to be rated at 14 amp , 700 volt . I don't recognise the manufacturer logo either .
    I would replace the drive chip also . Doubt it would have survived .
    Regards Zen
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      The driver IC is also tough to find info on. I don't have the board in front of me right now, since it's at the office, but we can just about make out the part number in this pic....
      I'd say it's MIP034c and below 714c4? (C or 0) - we won't know for sure until I look at it up close, but it doesn't matter because I tried every combination and nothing came up - HATE it when manufacturers do this and somehow manage to source the most obscure parts on the planet
      Wattevah...
      • zens electronics
        • Jan 2021
        • 31
        • uk
        Makes thrings very difficult for us , i know .
        No schematics ?
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          No, no schematics.....of course
          I tried searching for SU-HTB and indeed found a service manual, but the schematic isn't even close - that one has a separate STBY power supply, even some relays and sh!t. It's for a HTB500.
          Turns out there IS such a thing as "MIP" series IC, since on page 92 you've got IC5799 which is a mip2f20 which DOES at least return some results on google, as do other searches for "panasonic MIP IC". Meanwhile mine gets nothing...
          I'll try the transistor+resistors first and if it goes bang again, that's it - tough luck - it's going in the bin....
          Wattevah...
            • Jul 2011
            • 6070
            Dannyx
            Try this website to see if you can match the device manufacturer
            https://how-to.fandom.com/wiki/How_t...heir_logos/P-T
            I do not recognize this manufacturers logo
            There are no hits on this part number which is very strange most of time you would get something even if it is the wrong device ( but nothing at all weird ) unless it is a house part number
            Can you determine what the output voltage is by any chance————>
            I do not know if this will help you or not
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              The closest I can get to doing this is by assuming the part number on the transistor stands for 700v, 14A as zen suggested. Like I said - I'll dig through my parts bin and go with the highest spec'd I can find and just YOLO it...
              The output of the supply itself to the amp section could be anywhere between 30v and 60v based on my limited past experience with amps.
              The amp claims it's 120w...not sure if this is reflected by the transistor's ratings in any way, since it's a SMPS...
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                I ran a search on Aliexpress and it does actually throw some transistors in there, like 2n60f, so I'm actually curious if they're regarded as equivalents....
                There IS such a thing as SL701, but that's a different part entirely....
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Ok, I made some more progress on this thing: I actually managed to find the IC: it's a MIP004, when I thought all along the second 0 is a 6, so there IS an official Panasonic datasheet for it here. It's probably dead (Jim ), since the two 47ohm SMD resistors next to it are open-circuit, so I'm not risking firing it up like this.
                  For the FET, I dug through my drawer of transistors and after comparing and contrasting several types, I think I'll go with the P14NK50ZFP.
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Ok, I took a shot at powering it up today. I couldn't source a MIP004 anywhere, much less so in SMD form, so I just replaced those resistors and tried it with a lightbulb in series. Ironically, nothing explosive happened: the bulb went dim, but it also produced no output. Measuring the VCC pin of the IC, I can see it jumping between 0 and 19v repeatedly, so this makes me think it's dead and doesn't drive the output....I'm now hoping to be able to replace it with a "FAN" IC by comparing datasheets as much as I can....
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Ok guys, believe it or not I got this thing working I wasn't able to find a MIP004 IC in SMD form, so I got the DIP package instead - better than nothing - and botch-soldered it where the original SMD one used to be. I didn't want to use wires and extend the leads, which would've obviously made the job easier, because I was afraid the added resistance/capacitance would cause interference somehow and cause stuff to pop, so I kept everything as short and compact as possible.
                      Amazingly, it works, even in that ghetto state I sure hope it LASTS, especially once the subwoofer is connected which increases the load on the power supply, since I'm not sure what the specs of the original transistor was. I went with a P14NK50ZFP for reference.
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Just realized I mistakenly attached a pic of a CPU I was trying to sell too
                        Wattevah...
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          I had the same problem with this unit, unable to find the SMD version of MIP004, i replaced with DIP instead. Works fine but i used wire instead due to lack of space. A thick one
                          • lti
                            • May 2011
                            • 2557
                            I found that the manufacturer is Advanced Power Electronics Corporation (APEC, not ApECOR - there are two companies with the same name), but I didn't find that part.
                            http://www.a-power.com.tw/index.aspx?lang=eng&fn=index
                              • Jul 2011
                              • 6070
                              I like your ghetto fix you got to do what you got to do to make it work
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                UPDATE: since the post received some recent attention, I thought I'd just say the thing still works, since I haven't heard from the client since
                                Wattevah...
                                • SYNK Management
                                  • Dec 2024
                                  • 1
                                  • Malaysia
                                  Hi sir,
                                  Could you please share which components were replaced? I'm currently facing a similar issue with my Panasonic SU-HTB18. I came across your thread and would like to try fixing it myself, inspired by your successful case. Thank you so much for your sharing here!
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    Go through the thread again in order - it covers all the components I replaced. Good luck.
                                    Wattevah...
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      • United Kingdom
                                      14SL701
                                      • R_J
                                        • Jun 2012
                                        • 9607
                                        Seems to be AP14SL70I, I did find a datasheet for a AP14SL50I which might help
                                        Their website is Products | A-Power
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • khalillll
                                          maxipower 400W Dead power supply repair
                                          by khalillll
                                          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                                          After checking, I replaced the UTC7606D IC to restore the 5VSB.
                                          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                                          Replaced it again with another UTC7606D.
                                          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                                          After checking again, I think the issue was with the UTC7520D IC.
                                          Replaced it with a WT7520.
                                          Result: PSU fully working again
                                          09-27-2025, 05:06 AM
