440 g7 computrace
    440 g7 computrace
    can someone remove computrace?
    Re: 440 g7 computrace
    try..
      thanks, but when i install new os i cant skip intnernet connection.
      when i connect laptop is connecting to an firm.
        Originally posted by peste View Post
        try..
        I loaded your file but it shows like this, is there any way to fix it??
          try..
          file pass
            try this, enter the bios and restore the security settings to the default values and restart the laptop.
              thank you let me try
                i tried but it doesn't work-do you have the main file or any way to help me
                  Did you fix the issue, i loaded the same bios file and now have the ENDPOINT problem at boot
                    try this ... enter bios and restore security settings to defaults and restart your laptop
                      Tried the reset but still get endpoint error.
                        try..
                        thanks, it works!
                          can someone help, this is the original bios, but the laptop does not turn on on it
                            try..
                            working correct for HP 450-440 G7 da0x8mmb6d0 rev d
                              hello,
                              i need 440 g7 bios files ec + main,, my board worked today but i programmed 450 bios to my 440 mainboard... mainboard cannot work after update bios progress.. when i reprogram or clean me bios charge led on 15sec and no power on. thank yo
                                I send files and bios, try them please
                                [Mod. Edit-Vesko356] This is an english language forum, post in English please!
                                  try..
                                  Thank you kind person! My 440G7 is alive again!
                                  "Sure Start" put him into a coma, the BIOS recovery algorithm broke down.
                                  But thanks to you, these problems are a thing of the past!
