Oscilliscopes
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Oscilliscopes
    If you had $350 to spend on a scope, which one would you get?
    And does anyone know of a sub $50 multimeter that can read down to the 10s or 100's of µA ?
    sigpic
    • 31144
    Re: Oscilliscopes
    scope-wise, Rigol or Siglent.
      • Jul 2011
      • 6057
      Re: Oscilliscopes
      You might have to spend a little bit more money than this to find a good quality one for the money
      • petehall347
        • Jan 2015
        • 4430
        • United Kingdom
        Re: Oscilliscopes
        tektronix or hitachi
          • 31144
          Re: Oscilliscopes
          you dont get tek or hitachi for that price unless they are 20years old.
          that money can buy a brand new 4 channel scope from rigol or siglent
            • Jul 2011
            • 6057
            Re: Oscilliscopes
            Here is one model that might what you are looking for not this model number though
            MASTECH MS8239C
            I have use a Mastech meter before at a job over 10 years ago and back then there meters were pretty good back then I have no idea what kind of quality they have now
            Or this model that the picture is below I have used this meter for a while I have not used the UA setting before but have used the milliamperes scale and the amp scale and have no complaints about the use of it
            It does have Bluetooth capability and does work pretty good with the Apple application it works fairly good easy to use but it is very basic in design
            If I remember correctly it was under $50.00 on eBay
            I hope this helps you
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Re: Oscilliscopes
              My Sencore SC3100 I bought new for a lot more than $350 has been a great one. They can be had now in your price range. 100MHz, dual channel. Built in DMM and frequency counter.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Re: Oscilliscopes
                Extech's EX205T, http://www.extech.com/products/EX205T , lists for $44.
                Extech's MS240 20MHz, 2 channel digital oscilloscope (including probes and accessories), http://www.extech.com/products/MS420 , is $950. Being battery powered, it can be used to probe the primary side of a PSU. It also has a built-in DMM function.
                http://www.extech.com/products/MS6060 - 60MHz, $999
                PeteS in CA
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Re: Oscilliscopes
                  I own a Fluke 117 and had I known at the time that micro amps would be important, I would have chosen better. Just feels wrong to spend that kinda money again just to get microamps when I've got a good meter.
                  I dunno ... I'm sure ill end up biting the bullet and springing for the right one.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Re: Oscilliscopes
                    So Amazon has two Rigol's around $350 ... this one is a 2 channel 200Mhz and this one is a 4 Channel at 50 Mhz
                    THEN, I saw this sexy lil thing ... but it's a buck and a quarter over budget ... yet it might be worth it.... But just look at it ... it exudes class and style and it says ... "I'm gonna be here for a long time doing a damn good job"!
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Re: Oscilliscopes
                      So as I was looking at the Siglent page, I noticed a timer counting down at the upper right. When I clicked on the scope, the price was $474 ... but that timer was telling me that I had just 10 minutes to take advantage of some deal I stumbled on and the scope was at $424 ... so figured since I'm Amazon Prime if for some reason I don't like it, they will take it back no questions asked.
                      I went ahead and got it... should be here Monday.
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Re: Oscilliscopes
                        Here is the scope I ended up buying. It should be here Monday. It was a little over budget, but it seems highly functional with some cool technology in it including a web interface that can be accessed from anywhere. :-)
                        sigpic
                          • 31144
                          Re: Oscilliscopes
                          a very good scope.
                          i think you can even hack the software to upgrade it to 200MHz.
                          there is a thread at eevblog about that.
                          same for the rigol btw, you buy the 50MHz and unlock it to 100MHz.
                          but the siglent is better - and can go to 200MHz
                            • 31144
                            Re: Oscilliscopes
                            https://www.eevblog.com/forum/testge...-step-by-step/
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              Re: Oscilliscopes
                              Very nice!
                              I just haven't been able to let go of my old CRT scope....
                              Team : 49813
                              Join in!!
                              Team Stats
                                • 31144
                                Re: Oscilliscopes
                                what i want for my collection is a hybrid design from HP.
                                just before they went to lcd they produced a range of traditional looking scopes that where actually digital with a mini CGA? (24KHz) monitor in them!!!
                                the top model was colour!
                                unfortunatly every time one is on ebay some scumbag collectors who will probably never use it bid them up to stupid prices!!
                                same thing happens with HP bench meters - i know for a fact some of the buyers have 5+ of the same model just stacked for display/bragging rights!
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  Re: Oscilliscopes
                                  a very good scope.
                                  So it's already capable of 200Mhz, just have to hack it and enable it? ... sweet!
                                  sigpic
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    Re: Oscilliscopes
                                    But ... who are they bragging to? LOL
                                    Maybe you could find a broken one for a good price and fix it?
                                    sigpic
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      Re: Oscilliscopes
                                      Originally posted by Topcat
                                      Very nice!
                                      If you got table space to throw away ... then more power to you!
                                      I'm kinda the same way though ... if it works, seems like a waste to buy another one. That's why my last laptop was almost 10 years old before I bought a new one after it finally gave up the ghost.
                                      I even tried to save the old one... it just kept shutting down for no reason and after a lot of troubleshooting, I figured there must be microfractures in the lead-free solder on the mainboard somewhere so I even stuck the mainboard in the oven for 10 minutes to re-flow the solder. That actually worked for about a week or so till it started shutting down again... each time the re-flow only worked for a few days ... then a few hours ... then I finally just called the time of death and stopped CPR and bought a new one lol.
                                      sigpic
                                        • 31144
                                        Re: Oscilliscopes
                                        they are already broken on ebay.
                                        they are bragging to each other = posting pictures of their "collection" on eevblog!
                                          Lenovo IdeaPad 100S + Backpack Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 100S + Backpack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 100S + Backpack boardview and 100S + Backpack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 08:05 AM
                                          Lenovo IdeaPad 100S + SD16GB Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 100S + SD16GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 100S + SD16GB boardview and 100S + SD16GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Lenovo IdeaPad 100s Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 100s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 100s boardview and 100s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 100s...
                                          09-06-2024, 06:11 AM
                                          09-06-2024, 06:08 AM
